Old 10-30-2002, 07:27 PM
Tanked Tanked is offline
Really, really noisy rear suspension
The rear suspension creaks like no other - what's the best way to quiet it? Anytime I got over any kind of bump, it creaks, and if I press down on the back from the outside, I can also hear it.
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 10-30-2002, 08:36 PM
kris's Avatar
kris kris is offline
Off playing with fire.
ES BUSHINGS!
Actually, I really dont know. You could coat all the bushings, etc with wd40.
Old 10-30-2002, 08:49 PM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
i had this problem on my 88 DX, and people told me everything from the hatchdoor, to bushings, to struts....... welll thats actually the 3 things they told me...... so thats everything.... its probably the struts.... if you lower ur car anytime soon, ur probably gonna get new struts..... so its good...... so LOWER UR CAR
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 10-30-2002, 09:06 PM
Spraying WD40 around in there wouldn't harm anything?
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
Old 10-30-2002, 09:16 PM
91zc 91zc is offline
Nope...wd40 is just a lubricant and rust "breaker". It won't harm anything.
91 civic 4dr
b16a
14.8@94
Old 10-30-2002, 09:21 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
wd-40 wont do anything but gather dust and dirt, try bouncing your struts, noise may be from them...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 10-30-2002, 10:56 PM
EFsleeper's Avatar
EFsleeper EFsleeper is offline
Send a message via AIM to EFsleeper
I would have to disagree with you. WD40 is a cleaner more than it is a lubricant. Its great for lubricating the hinges on the door to your bedroom but for your car stick to real lube stuff.... It may quiet those bushings down a bit though. I would check the hatch first. The hatch is usually the main cause of squeaks in 4th gens.
Stop looking at my Autometer!
Old 10-31-2002, 07:03 AM
Hmmm...I use wd40 to lubricate stuff all the time and it works just as well as any other product I have used
WD40:
PENETRATES: WD-40 loosens rust-to-metal bonds and frees stuck, frozen or rusted metal parts.
LUBRICATES: WD-40's lubricating ingredients are widely dispersed and hold firmly to all moving parts.
PROTECTS: WD-40 protects metal surfaces with corrosion-resistant ingredients to shield against moisture and other corrosive elements.
CLEANS: WD-40 gets under dirt, grime and grease to clean. It also dissolves adhesives, allowing easy removal of labels, tape, stickers, and excess bonding material.
DISPLACES MOISTURE: Because WD-40 displaces moisture, it quickly dries out electrical systems to eliminate moisture-induced short circuits.
91 civic 4dr
b16a
14.8@94
Old 10-31-2002, 10:35 AM
dumpedhatch's Avatar
dumpedhatch dumpedhatch is offline
squeky
i had the samer problem on my hatch it was the struts. and also wd-40 is great. when you use it to clean something it leaves a nice shiny look.
Old 11-01-2002, 12:03 AM
civicracer_1990's Avatar
civicracer_1990 civicracer_1990 is offline
squeak...
my hatch does the same shit man....sounds like I'm walking through a haunted house...damn civics.....
Old 11-02-2002, 12:16 PM
Any idea how much a pair of struts would cost?
2003 Civic EX 4D
D17A2 (Stock)
5-Speed Manual
