Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-20-2007, 09:06 PM
94HeavyChevy 94HeavyChevy is offline
rear end
i want to change my rear end real soon...i have a 94 caprice with a 5.7L 350 and the rear end is a 7.5 inch with 2.73s....im thinking about switching to the 8.5 rear but i cannot decide what gears i want to put in... at the most i will go with 3.42s but what kind of rpms will i be looking at on the highway cruisin at 80 or so....lowest i would go is 3.08s....is there any gears i can put in either rear end between 3.08 and 3.42..should i definetly get an 8.5 inch rear or can the 7.5 handle 3.42s?? any help or suggestions are appreciated
Old 06-20-2007, 10:39 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: rear end
An 8.5" 3.08 w/rear disc brakes out of a '94-'96 9C1 is a bolt-in replacement, provided you get the driveshaft that goes with the donor car.
My '88 is running a '94 9C1 rear axle set. Works grrreeeeaaaaatttt!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-21-2007, 05:35 AM
CD Smalley CD Smalley is offline
Re: rear end
Wouldn't a 94 already have an 8.5" rear? Especially if he has a LT1? And he'd should have 3.08s too with an LT1.
How have you verified your 7.5" and 2.73s?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-21-2007, 10:07 AM
Re: rear end
car came with an 4.3L 265 L99 and i had a 350 put in it about a year ago....where can i find a 8.5 rear?
Old 06-21-2007, 10:23 AM
silicon212's Avatar
Confoundingly Lucid
Re: rear end
Well, that explains the 2.73 gears. Anyways, junkyards, etc. I picked mine up for $130 complete.
CD, the civilian LT1 cars typically come with 2.93 gears, but I do think you're right in that it should be an 8.5".
Old 06-21-2007, 11:06 AM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: rear end
I gotta come down to AZ sometime and get a truckload of parts. Cheap, rust-free stuff.
