Go Back   Automotive Forums Car Chat > Dodge > Stratus
Old 06-20-2007, 06:12 PM
recycle_me's Avatar
recycle_me recycle_me is offline
Send a message via ICQ to recycle_me Send a message via AIM to recycle_me Send a message via MSN to recycle_me Send a message via Yahoo to recycle_me
A small problem causing big headaches!
for the car info
1996 Dodge Stratus
2.0 single cam
manual trans
Stuff i replaced
coil pack plugs wires fuel filter
Problem
Ok while driving around with the ac on if i come to a red light the car will stall out. The rpms will drop and not catch back up. If i drive around with the ac off it will not even stall out! What weird is the car will not idle up when the ac is on. it idles at 700, i even tried to turn the idle screw up and it still idles at 700. It also uses a lil oil. But it doesnt blow any smoke of any kind and its not in the anti freeze. So any clues poping out at ya that might be a fix to this? Thank you for reading and for the advice you give. i have done some research and im just looking for a lil more pin point before i go changing egr valve cat or crank or cam sensors. Thanks.
For You Are Crunchy And Taste Good With Ketchup!
Old 06-25-2007, 09:48 AM
taillight taillight is offline
Re: A small problem causing big headaches!
Look for a leak in a vacuum hose. If you can, connect a vacuum gauge to the intake manifold and look for about 17" of vacuum and stedy. If not look for a vacuum leak.
Old 06-26-2007, 03:40 PM
recycle_me's Avatar
ok thanks for info ill go do that
Old 06-29-2007, 05:39 PM
gabbygail gabbygail is offline
the check engine light is coming on my 2004 dodge..it came on while driving on the highway..it had flashed previously but now is on solid what could cause it?
