Old 06-20-2007, 05:15 PM
knucklescw knucklescw is offline
seafoam
i put a half pint of seafoam in my intake and it stops the lifter tick for about two weeks. could i use it every two weeks or should i just use it every once in a while.
Old 06-20-2007, 06:20 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: seafoam
I would just buy some new 3rd gen lifters.. I think they are doin a group buy on 3si.. somthing crazy like 130 for all the lifters!! anyways.. thats the best deal i have ever herd of
Old 06-20-2007, 06:39 PM
Dreamspawn's Avatar
Dreamspawn Dreamspawn is offline
Send a message via AIM to Dreamspawn Send a message via MSN to Dreamspawn
Re: seafoam
i wouldnt' seafoam that often i think it says once a year recommended.... but yeah the group buy is rad also try differnt oils....
Old 06-20-2007, 09:00 PM
dhrubio's Avatar
dhrubio dhrubio is offline
Send a message via AIM to dhrubio
Re: seafoam
yea i did the 99 lifters a couple weeks ago, not as bad as i thought.....once you do the first couple you get the hang of it
Old 06-21-2007, 12:13 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
Re: seafoam
i definately need to seafoam the vr4
Old 06-21-2007, 12:41 PM
new2mitsu new2mitsu is offline
Re: seafoam
were can u get the stuff, do they have it at az or ne where?
Old 06-21-2007, 12:53 PM
dhrubio's Avatar
Re: seafoam
i got it at advance auto parts...most places should have it
Old 06-21-2007, 03:17 PM
Re: seafoam
is the stuff safe?
Old 06-21-2007, 03:28 PM
dhrubio's Avatar
Re: seafoam
if you do it right....i read through all the threads i could find about it and in sum, the best way to do it i believe is: 1/3 can in gas tank and 1/3 can thru brake booster line(put the 1/3 in a bowl or something, then use a hose n just barely touch the surface of the seafoam with the hose and it will start sucking...have someone there to rev the car only a tad to keep the car on until the seafoam is gone)..then let the car sit for several minutes (some say 5 some say 30)....then turn it on and rev until theres no smoke left...then put the other 1/3 in your oil but do not rev!!!..again let sit for a while, then drain oil, then run car with cheap oil for a few minutes to rinse out the chemicals, then put fresh oil.....feel free to chime in anyone else..
Old 06-21-2007, 04:23 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: seafoam
No need to run the car with cheap oil to get the chemicals out. If there is any seafoam at all left after draining it will be extremely negligable.
Old 06-27-2007, 12:29 PM
jmaggio jmaggio is offline
Re: seafoam
Could somebody please post a picture with an arrow colored in from Ms Paint or whatever so I can be positive what line to unclamp from my 94 Stealth RT
sorry for the noobness but I've put too much money into this car already
Jason
Old 06-27-2007, 02:19 PM
dhrubio's Avatar
Re: seafoam
Pics
Old 06-27-2007, 06:09 PM
Re: seafoam
Very good thanks!!
