Old 06-20-2007, 03:09 PM
bkluby bkluby is offline
Need 98 Grand Prix Technical Specs
Can anyone tell me the torque specs for the Rocker bolts and Intake manifold bolts? Also, should I use lock-tite on the Intake bolts, I noticed one was loose before I took it apart.
Great Appreciate your help.
Old 06-21-2007, 12:03 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Need 98 Grand Prix Technical Specs
Welcome to AF.
Your post has been moved to the regular part of the Grand Prix forum from Tips & Maintenance.
It would help to post what Grand Prix model and engine you have. The 3800 VIN "K" or 3.1L VIN "M"?
For a SII 3800 engine:
11 ft-lbs for LIM bolts. Yes, use the threadlocker on the bolts but make sure any old is removed first.
UIM bolts = 89 in-lbs.
Rocker arm torque is initially 11 ft-lbs plus an additional 90 degrees.
Timeslip 08/12/06
AF Community Guidelines
Old 06-21-2007, 08:36 PM
Thanks for the 3800 specs, but I have the 3.1 L. Do you have those specs?
Old 06-21-2007, 11:41 PM
BNaylor's Avatar
3.1L VIN "M"
Rocker Arm:
14 - 20 ft lbs
LIM Bolts:
4 top bolts to 5 ft lbs
2 side bolts to 5 ft lbs
4 top bolts to 10 ft lbs
2 side bolts to 18 ft lbs
UIM Bolts:
18 ft lbs
Timeslip 08/12/06
