Go Back   Automotive Forums Car Chat > Ford > Escape | Maverick | Escape Hybrid
Old 06-20-2007, 12:14 PM
moorhoub moorhoub is offline
bearing noise or transfer case issue?
I have a 2005 4x4 V6 , with a noise in the backend that sounds like a wheel bearing. i have taken it to a garage who said its not the bearings, its just the tires.
Does this make sense? read a previous post about a transfer case making a bearing noise, and just wondering if that could be my problem.
When using the system check on the dash it says the 4x4 is fine.
Is there anyway to test if the 4x4 is working ok, or to narrow down the source of my noise?
Thanks
Old 06-22-2007, 10:04 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: bearing noise or transfer case issue?
Did you look at the tires? Is the inside tread choppy since this is a common issue?
Old 07-15-2007, 10:19 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Jack it up with all four tires off the ground and run it.
Best way is on a lift, but I had to use four jack stands.
Is it four wheel drive?
