Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-20-2007, 11:30 AM
johnholl johnholl is offline
exhaust flex pipe needs replacing\ 93 sl 1
DYI project?
My flex member, located under the powertrain assembly- post manifold, is leaking. Any one have any suggestions on how to repair, or replace it with an aftermarket flex-pipe? If need be, can it be cut with a cutter wheel? [not much working room under there]
John
Old 06-22-2007, 11:43 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: exhaust flex pipe needs replacing\ 93 sl 1
universal replacements are availible, but a direct fit replacement is your best bet. contact your local dealership for the part. it should be bolt-in, no cuting needed, assuming the bolts aren't completely seized. then a oxy-acidiline torch is need. at less try a propane torch to heat the bolt and break loose easilier. air tools are also recommended because of the rust and tight spaces(namely where the downpipe connects to the manifold)
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 06-29-2007, 11:18 PM
RickMN RickMN is offline
It's a dirty job, but yes, it's a DIY job with a cutter wheel, perhaps an air chisel, a lot of rust pentrant and patience. Make sure you wear goggles--that's rust can really damage your peepers.
I'm a retired ASE Master/L-1 Technician. I still keep current with the latest automotive technology.
