Go Back   Automotive Forums Car Chat > Porsche > 924/944/968
Old 10-30-2002, 03:34 PM
Jed944 Jed944 is offline
Send a message via AIM to Jed944
Turbo on 944 S
Is it possible to put a Turbo in with the 944 turbo S motor? what is needed? what needs to be changed? how much psi could i run?
Drive faster, drive harder
Old 11-03-2002, 04:45 PM
I geuss nobody knows about this...
Old 11-15-2002, 05:36 PM
Cbass's Avatar
Cbass Cbass is offline
Send a message via ICQ to Cbass Send a message via AIM to Cbass Send a message via MSN to Cbass Send a message via Yahoo to Cbass
I know about this, you'd have to lower the compression drastically, to around 8:1, you'd have to get an ignition controller, to retard the timing, and you'd have to get a fuel controller, so that your engine get's more fuel under boost.
You'd also have to fabricate completely new exhaust, a new header, and add an intercooler as well. If you're up to rebuilding your engine and spending a few thousand doing it, go ahead... It would be much simpler, and probably a better idea just to get a 951 engine, because it has everything except the DOHC head.
Connor - Porsche Nazi since 2001, VW defiler since 2004
This here's a Fabrication forum!
My lugnut requires more torque than your LS1 makes.
Old 02-03-2003, 08:02 PM
s2o0os s2o0os is offline
Send a message via ICQ to s2o0os Send a message via AIM to s2o0os
Well, I went to a Porsche repair shop here in Miami and a guy there told me that it isn't a good idea putting a turbo on my 944 just because the 944 turbo model engines are made differently from the non-turbo models. He told me that it's better to just buy the turbo engine with the turbo because putting a turbo on a non-turbo engine will kill the engine after sometime. I don't know how different the 944 S is from the regular 944, but make sure it is save.
Old 02-14-2003, 10:03 PM
Cbass's Avatar
It's not hard to do at all, and it won't kill the engine, if you do it right. Of course, doing it right means changing lots of parts, and they don't come cheap
The 944 S engine was a DOHC version of the 944 engine, and I think it displaced 2.7 liters.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
