Old 06-19-2007, 11:33 PM
chart chart is offline
1986 chevy 3/4 ton
i recently got a 1986 3/4 ton 4WD 350 ( not fuel injected) truck. the front axle doesnt have the things to lock in the hubs on the front axle for 4wd. also, in the cab the 4wd shifter only has 3 notches. one up, a middle, then a down (so to speak.) is it all time 4wd. if so how does that work. otherwise are they automatic locking hubs or something. ALSO. i put a rebuilt engine and tranny in it. the odometer reads 235,000 miles. is there any way to roll it back or can only dealers do that.
Thanks in advance. Chart
Old 06-21-2007, 08:30 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1986 chevy 3/4 ton
Illegal to tamper with a odometer reading
You can even get jail time out of it.
Most of them was a old style full time 4W setup.
You can put a lockout hub kit on the front axles but you need to put a change over kit in the transfer case at the same time for it to do any good.
MT
MT
Old 06-21-2007, 09:28 AM
777stickman 777stickman is offline
I had an '88 Blazer 4wd. It had the "auto hubs". Don't remember what the shift pattern was. They lock in when you shift to 4wd and drive forward. To unlock them you have to go to 2wd and back up (a real pain if you have a trailer hooked up). My old '78 Blazer has the full time system. It has a 5 detent shift pattern. 4low lock, 4low, nuetral, 4hi and 4hi lock.
I'm pretty sure your '86 has the "auto hubs". I'm pretty sure you can pull the "auto hubs" out and replace them with manuals, but you should talk with a good 4wd source to confirm.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 06-25-2007, 05:30 PM
broughy84's Avatar
broughy84 broughy84 is offline
If this is a Full time 4x4 truck, which it sounds like it is, It is not going to do you any good to change the hubs to manual lock outs. Your transfer case is still going to be putting power to the front axle, which is a bad thing if your lockouts are not locked. If you really want to get rid of this you need a different transfer case and front lockouts.
Don't mess with the odometer, big trouble man!
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
