Old 06-19-2007, 10:21 PM
Enzoenvy1's Avatar
C6-R in 24 hours?! Le Mans build 0f 6-16-07.
Well, I will start off with stating that I simply cannot build OOB for anything - ever!!! I knew I could have the body and chassis prepped for the race, but I spent so much time fixing crap that I simply had no time. In the end, I passed out around 4:30 last Sunday morning after 20 continuous hours of Corvette angst. I can honestly say that I did complete the model aside from decals and adding lights. If it were a just painted C6-R then I would have accomplished my task. But, it was a as is running Vette and I couldn't do it. But I learned so much about techniques that I would never trade the experience. So,..........here is the build of my #64 GT1 Le Mans Corvette C6-R.
Like I said, I was able to have the body primed. So last week I started by seeing what was good and bad with the Revell kit. Since this is my first ever Revell build (I am partial to Tamiya cause they are the best), I can't say if it is a bad kit. Most pieces fit really well, but the chassis pan was warped and the body had a lot of fill where it was not needed.
Like the real car, the front air dam is open and these pieces needed to be removed:
Here is the first cleanup of the damn. I broke the three inside slats on accident, but the purpose was needed. If you look at a real car, the three middle slats sit behind the mesh, and the 4 outer slats sit on the outside of the mesh. Here is the beginning:
The rear also has a cutout where a license plate would go on a street vette. On the race car it is not filled, but rather there is a mesh in its place:
So, that was removed and voila:
Next I looked at the rear diffusers and noticed that this is completely inaccurate for the C6-R. Revell only cast 7 diffusers wheras the real car has 15!!!
Here is the progress on the diffusers:
The lip of the diffusers had a curve to it, and that was also inaccurate:
So I filled the back and cut out the curve:
Old 06-19-2007, 10:30 PM
Enzoenvy1's Avatar
Re: C6-R in 24 hours?! Le Mans build 0f 6-16-07.
Now, 15 new diffusers had to be made:
Here are the first two, and the beginning of a head ache:
But, I made it work:
Some might think they are not all the right length, but I staggered the 5 main diffusers to be longer and the inners progressively shorter. Here is the finished product:
The dorr gaps were really crappy:
The spoiler mounts were completely inaccurate for the car as of race day in 05'. And Revell decided I only wanted one of them so I had to make new ones (more to come). So, I filled the holes in the body:
The green door light were simply dimples in the plastic. I wanted to put BMF in the holes and use green paint. So, I drilled out the holes to make the walls less round:
Here you can see how thick the doors were. The dremmel loved it!
So, I backed the part with Styrene and got this:
Old 06-19-2007, 10:37 PM
Enzoenvy1's Avatar
Bumper after attempt 3:
Now, the rear NACA ducts were in one piece and not attached to the body which is wrong. So, I measured and cut them off. Then glued them to the body:
Ok, things were going well, but then came Saturday and the race and I was not ready for anything close to primer. Then I noticed that I needed to add Styrene to all the door sides, and the hood. Anyone who has done this knows it is kind of easy, but time consuming:
Old 06-19-2007, 10:48 PM
Enzoenvy1's Avatar
For fun and reasons unknown, I took pics of the clock to piss myself off. Here is where I was at:
Dash came in two parts that did not fir together at all. So, I added some putty and prayed it would dry in time:
Here is what Revell gives you for spoiler supports, it is the chrome one:
Here is what I had made, they were even curved for the angle of the spoilers surface:
Here is where they should be:
And the result:
Had to fill the spoilers sink holes:
Both doors and hood completely fitted:
Old 06-19-2007, 10:53 PM
Enzoenvy1's Avatar
Here was everything that needed to be semi-gloss black:
The dash after sanding smooth and painted. I think it looks great:
Now, the front damn, again. I marked where the three slats needed to go:
Like I mentioned earlier, I had to recess the three middle ones so that the mesh could go in front of them. It took a really long time to do this, and I was mad:
Here is what they look like from the front:
And here is the test fit with the mesh. I am so happy I did this as it looks great!!!!:
Time is flying:
Now, finally the body is sanded and ready for primer:
Old 06-19-2007, 11:11 PM
Enzoenvy1's Avatar
Well, the chassis is about finished. Here are the diffusers after paint, and I am loving the look!:
Here are the windows trimmed out:
Oh My Gosh there is paint!!!!!! Well, after 3 primer coats and sanding. I stripped the chrome sprue with Easy Off, and that stuff was amazingly quick! Here are a couple of wheels in Tamiya Gloss Aluminum, and the body in Tamiya Camel Yellow:
The tires were hysterical and so smooth that they could not be real:
So I sanded them down with 400 grit to make them look more realistic:
Time was flying by:
Our apartment smelled like a paint shop!!! I was painting outside to, lol:
This was the 4th coat of paint and I was not touching it anymore.
Starting on the interior:
Brakes were supposed to be flat red, but the real car had Gold colored brakes:
Still flying:
I know, I know, not the way it should be, but I was not about to waste a ton of time on the interior:
Old 06-19-2007, 11:12 PM
360spider's Avatar
Wow! Superb!
Old 06-19-2007, 11:24 PM
Enzoenvy1's Avatar
Brakes added:
Here is the paint after it dried for a couple of hours - smooth as glass already!!!:
SO, this is where I made to at 4:30 am. The race would have ended in 3 more hours at that point. If I could have stayed up, then I might have had it completed. But, the saving grace is that I had time to let the body dry all of the way. The next day was Dad's day so no more building. Monday I did the decals and that lone took about 2 hours. I have never decaled that much on a single car. I have never cleared with TS-13, but I felt I should to level out the decals. Here is what it looked like before I possibly ruined all of my work cause of the eating of TS-13:
Well, guess what happened?! The clear worked flawlessly!!! lol I layed 3 mists and a couple semi-heavy coats to it. I can honestly say that I have never had such a successful paint job ever!!! I don't even need to polish or wax it, it is that shiney!:
Today I added the BMF'd lights, the spoiler, and it only needs a couple of touch ups here and there. Other than that, it is finished. I hope to post it tomorrow, but work will not allow until night, and I want this one in the sun. I hope you all like what I did. I really did try to make it in 24 hours, but this was a big challenge. Please comment and criticize if need be.
Jon
Old 06-20-2007, 02:51 AM
kingkai's Avatar
kingkai kingkai is offline
looking to clean for my liking. No just kidding, Awesome job
Old 06-20-2007, 03:32 AM
WasteGas's Avatar
WasteGas WasteGas is offline
One hell of a marathon building! Show us more!
Old 06-20-2007, 03:54 AM
godfather23's Avatar
godfather23 godfather23 is offline
Respect and even mor respect for what you have accomplished in that short period of time. The bodywork looks great!
Keep your enthusiasm up!
Robert
Recently finished Projects:
Porsche 911 Carrera RS 3.0
Current Projects:
Old 06-20-2007, 11:39 PM
69*Goat's Avatar
69*Goat 69*Goat is offline
Very nice work in a short period of time. You have inspired me to start on mine.
I have a couple of questions....
Ho, w tall are the diffuser pieces that you made?
What mesh did you use for the front grille, and rear opening?
TIA
RW
2015 Z/28 Camaro
10 Toyota Rav4 Limited (Wife drives it)
2017 Silverado
Old 06-21-2007, 04:32 AM
kingkai's Avatar
What did you used on the dremel, for sanding the doors down?
Old 06-21-2007, 04:49 AM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Hey! The mods you done to fit doors right and on the front hood are at a PRO level: I see you skills increased dramaticaly! Great job so far.
The most funny thing is the WIP of your fingers LOL!!! Dunno know glowes? LOL
ciao, and BRAVO!
gio
gio
Old 06-21-2007, 09:51 AM
hompe's Avatar
hompe hompe is offline
Amazing did you have any time too watch the race?
Hompe
