Go Back   Automotive Forums Car Chat > Chevrolet > Cobalt
Old 06-19-2007, 10:01 PM
6Cobalt 6Cobalt is offline
Shift Points
I have an LS, and would like to get a little more bang out of it. The cheapest way to do this I beleive would be to change the shift-points. It's an automatic, so I'd need to get under the hood for this. So here are my questions:
1) can I do this on my own? if not, where do I need to go
2) where is the connection to the computer, what do you need to connect to it? jacks, programs etc.
3) what should I change the points to?
4) this is just stupid but: are SS engine parts able to be fitted to the LS?
if you can answere these, particularly the first and third, I would be forever indebted to you.
Old 06-20-2007, 10:03 AM
rodeo02 rodeo02 is offline
Re: Shift Points
If that's the route you want to go, "B&M Shift Plus" is one type of controller that can be spliced into the harness of your 4T45E. As far as I know, you locate two wires out of the trans harness loom and tap two B&M wires to them with TapCons. No need to even cut/splice wires. You route the hand-held controller part into the cabin so you can adjust on the fly. You could probably have a custom tuned PCM done as well and I'm sure there are more 'electronic manipulators' for the 4T40E/4T45E. Dropping the valve body and doing a mechanical shift kit may be possible too, but I don't know why you'd want to on a stock 2.2L Cobalt.
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 06-20-2007, 11:02 AM
-Jayson-'s Avatar
-Jayson- -Jayson- is offline
Re: Shift Points
no there is not way to adjust the shiftpoints on your car right now. Unfortunately the only company that has tunning software for the cobalts, currently does not support the 2.2L engine. I HIGHLY advise against using a B&M shiftplus, its harmful to the trans and does nothing more than make your transmission slam into gear. You cant tune anything with it or do anything to the trans. All it will do is increase the line pressure and cause the trans to shift much harder. Ive used one before and had bad results, i highly do not recommend it.
2009 Ninja 650 R
stock for now...
SouthEast Ecotec Enthusiast
Old 06-20-2007, 02:15 PM
Re: Shift Points
That's what all your electronic or software 'tunes' will do to an AT. If you want hard, fast shift points, more RPM's between shifts you will shorten the life of the transaxle and engine. The old saying you will to pay to play.
Joel
Old 06-20-2007, 03:34 PM
-Jayson-'s Avatar
Re: Shift Points
Joel
correct, but theres a huge mistake your making, it doesnt make it shift faster on a car that isnt running alot more HP. It just makes the shift more noticeable. Theres a whole nother section in the PCM that controls how fast the shifts are. This just pushes it into gear with more force, not faster force. Usually people who use this are running alot more HP than stock, and the shifts slip, then it will increase your shift time.
Also i dont recomend it because the settings are 50% and 100%. Both of which are way more line pressure than what is needed. As well as a B&M shiftplus wont make your car faster, cause like i said it doesnt improve shift times on a stock car.
2009 Ninja 650 R
stock for now...
Old 06-21-2007, 03:13 PM
Re: Shift Points
Good points Jayson. Line pressure and shift points are two separate variables. Neither of which I would mess with (much) on a stock engine.
Joel
Old 06-21-2007, 09:16 PM
Re: Shift Points
what about the SS parts? Is there any way to get a little more kick out of this car? Believe me, I like the car, but I'm wishing I could have afforded payments on something racier. Now I'm stuck trying to squeeze extra power of a 2.2
Old 06-24-2007, 08:41 AM
Black07LS Black07LS is offline
Re: Shift Points
If you want controll shift points the best way is get a 5sp. If you want more power/preformance go to CobaltSS.net and find the 2.2 forum
Old 06-24-2007, 11:26 AM
-Jayson-'s Avatar
Re: Shift Points
The SS 2.4 and SS 2.0 both have tunning software that allows you to completly tune everything about the car. From spark advance, af ratio, shift points, shift time, rev limiter, governor, anything GM can do, you can do.
If you want more performance just buy a SS supercharged and dont go automatic if you want to have fun.
2009 Ninja 650 R
stock for now...
