Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-19-2007, 08:30 PM
evildragon evildragon is offline
tires, rain, and bogging
Well, my Caprice has had an interesting development in the mysterious hesitation. It was pouring rain today, and man did my car bogg on me! It felt like it was going stall, but didn't. It only does this it seems, when it's raining.
In the same session as above, when I pulled out of a parking lot and hit my brakes, to my surprised the wheels locked when I BARELY touched the break, I thought I hit something. I thought when the breaks are wet they slip, why did mine lock up like that?
Also, my front left tire is developing a weird taking-in-air habbit. I have had to let air out of that tire atleast 2 times now. My particular tires are supposed to be 35 psi each, and for some reason, within a week, my front left tire gets up to 40 psi! (that's the max psi for these tires) What in the world! My father keeps saying I'm on crack, lol, but seriously, somehow air is getting IN to the tire.
My one and only car!
1994 Chevy Caprice Classic LS
L99 Engine
Old 06-19-2007, 08:46 PM
CD Smalley CD Smalley is offline
Re: tires, rain, and bogging
Well the running like crap in the rain indicates an opti-spark failure to me.
Bald or nearly bald tires could cause the brakes to lockup. Wait a minute though. That car should have ABS. You should have no lockup....
Regarding the tire pressure... are you checking it at same time each day? Also, outside temperature will effect the pressure.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 06-19-2007, 09:05 PM
OptiSpark, I keep hearing this name. Is this the distributor? (I think I was told once, but I forgot).
Yea, the car has ABS, so I have no idea why it didn't kick in.. The breaks are usually fine and work great, and have saved my life countless times in the florida traffic.
I check the tire pressure always at 3pm...
L99 Engine
Old 06-19-2007, 09:59 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
My Sierra does this EVERY time it rains, and it has ABS too. It's from all the moisture sitting parked makes the barkes rust... real fast. Then the first couple of times hitting you brakes they will grab hard until the rust is worn off.
Old 06-20-2007, 05:57 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Bogging issue: How are your spark plug wires? Also look at the distributor cap.
Brakes: My non-ABS brakes will get grabby after a good rain, only for a few stops then they're ok. The organic pads suck up the moisture.
Tire gaining air: They tend to do that is pressure is real low. The sidewall flex causes them to build up pressure. Take a good look at the sidewall for any bubbles or waves on the surface. Try to check the pressure with another gage and compare it to the one you always use. Check them dead cold before you do any driving for the day.
Bob
