Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-19-2007, 06:19 PM
joeym joeym is offline
electric fans not working
First time posting.
1991 Camry Wagon, 4 cylinder, auto.
I'm trying to troubleshoot why my electric fans are not working on my camry S.W.
I need to get (if anyone has these) stats so I can test the sensor on the TStat housing. Also, I have checked the circuit breakers on driver and passenger sides that checked out well. I know this doesn't matter, but I replaced the TStat also.
I have checked both fans individually and they work.
My last suspect is the relay/relays. I believe there are 4?
My questions: How do I check to see if the relays are bad?
Figures on the t-stat sensor: What are they so I can test?
Whats else could I be looking over?
Old 06-19-2007, 06:40 PM
somick's Avatar
somick somick is offline
Re: electric fans not working
There is a link to the repair manuals at the top of the forum.
Look there for your model year and good luck,
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-19-2007, 06:48 PM
Thanks Sam...
Old 06-20-2007, 12:01 PM
Has anyone had issues with their electric fans that they could share some info about?
I'm still trying to troubleshoot my electric fans not working, and it's somewhat involving. Looking to see if maybe someone has some experience with electric fans that seem to have issues in Camry's with the 4 cylinder.....
Old 06-24-2007, 11:18 PM
Resolved the electric fans issue! And I was able to find the bulb that was keeping the "lights" warning on the console...
Thanks to the manual, and the instructions in there, I was able to test the relays and the temp sensor. Turns out that I had/have 2 bad relays: Engine Main, and AC Fan No.2.
I went to my local southwestern auto parts and was able to locate the engine main relay ($21.00), but I had issues finding the AC Fan No.2 relay with them. Going to do some searching tomorrow for that relay.
Ultimately, it was the "Engine Main" relay that was keeping the fans from working. I was able to know somewhat immediately after plugging the new relay in, I unplugged the temp sensor from the T-Stat housing, put my key in the ignition in the "on" position, and the fans went on immediately. Interesting that the car would still start with that relay being bad, and, without it even being in the fuse/relay box itself!
Old 06-25-2007, 12:17 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Hey, thanks for posting the fix. Proof manuals can be a big help if you take the time to download and read them. Many don't. Cheers!
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 06-25-2007, 06:39 PM
Your Welcome, and I am glad to help what little I can...
Old 06-26-2007, 12:03 AM
JOET/CAMRY JOET/CAMRY is offline
I believe this warning light lets you know if one or more of the tail light bulbs or break light bulbs are out. did you just remove this annoying light bulb? it kinda sounds that way from your remark.
Regards,
JOET/CAMRY
