Old 06-19-2007, 06:12 PM
civic&240 civic&240 is offline
Send a message via MSN to civic&240
running rich?
i just got my car on the road and noticed its smokey. people say they see blue but ive only seen black. i check the codes and it blinked once.. then 16 times..which says it fuel injectors in the book. does any one know what would cause this and how i can fix it,?? any help would be good, thanks
Old 06-20-2007, 12:46 AM
YZ125rider21's Avatar
YZ125rider21 YZ125rider21 is offline
Send a message via AIM to YZ125rider21 Send a message via Yahoo to YZ125rider21
Re: running rich?
more info on what engine you are running....and pull each injector while its running and see if its making a change in idle....also 1 is o2 so I get anew o2 from kragens for 20 bucks which has liek a 2 year warranty....cause you might have a fuel injector stuck open causing the code
90 Honda CRX Si
-Red/Black
-B20B/b16
-AEM CAI -/\- Apexi GT Header/2¼" Custom Dynomax Exhaust
-Tein SS CoilOvers with pillow ball monuts -/\- ST Swaybars/Energy Suspension Bushings
-16x7 Lightweight Rotas -/\- Pro Stop Rotors -/\- Goodridge S.S. Brake Lines
-Skunk2 Shifter -/\- MoMo Steering Wheel
Old 06-20-2007, 08:12 AM
Re: running rich?
thanks all try that,and its a d16a6 and i put a new o2 in last night and not much off a difernce.
Old 06-20-2007, 08:27 PM
Re: running rich?
ok well check your ignition make sure its all right...something causing unburned fuel....but I figured might be a leaky injector stuck wide open sense you getting that code...
90 Honda CRX Si
-Red/Black
-B20B/b16
