Old 06-19-2007, 09:59 AM
Jmoney3318's Avatar
Jmoney3318 Jmoney3318 is offline
Send a message via AIM to Jmoney3318
Wet floor
Alrite so it was pooring rain last night and i go to my car the next morning and the carpet behind the driver seat like the floor infront of the backseat is freaking soaked .... the problem is i dunno where its comin from, theres no leaks in the sun roof nor and signs of leaks in the roof. recently i locked my keye sin the car and the guy idd something with the door is it possible that could might cause it. and im positive that i idnt leave the windows opened cuz it sonly that part of the car thats wet, the seat and evreything up front is fine....any ideas or suggesitons?
my Cardomain
2002 3.4L V6 GA Coupe
-Xero is my hero--
mods:
Suspension: KYB GR2s, Intrax Lowering Springs, Upper Front Strut Bar
Engine: Custom 2.25" Exhaust,Doctorspeed Cold Air Box
Old 06-19-2007, 10:42 AM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: Wet floor
Sounds like the drains for your sunroof are clogged. It's a common problem, along with the seal along the firewall leaking which floods the front of the car.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 06-19-2007, 11:56 AM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Wet floor
So when you locked the keys in your car did he pop out the window or what ?
These models are leakers!!!
Feel around the headliner by the sun roof over too the door,
and the carpet by the door opening.
Could have just not had your rear door shut all the way which can happen.
As skibum said the roof drains leak.
What I've seen is that they put the hose for the drains on before paint. Paint dries and shrinks causing hoses to crack and then leak.
They also get pluged and overflo into the cabin.
Which that leak is caused by the sunroof gasket not sealing properly.
My GT needs one but I'm not wasting money on something I dont use anyway.
I just siliconed it closed and pulled the fuse
Good Hunting !
1999 Grand Am SS 3.4 OHV
Old 06-19-2007, 04:03 PM
DepecheFan08 DepecheFan08 is offline
Send a message via AIM to DepecheFan08
Re: Wet floor
I was thinking about starting a thread on this. I have an exact same leak. After it rains, the floor behind the drivers seat is totally soaked and the floor in front is moderately wet. Passangers side is absolutely dry..nothing there.
I tore the entire car apart to figure this out...cleaned the drains, checked the firewall. Came to a conclusion it was the panel on the drivers side door that was slightly coming off. Sealed that and hole on the bottom between the floorboard and the bottom of the car which is where I thought the water was going through after it leaked through the panel. And it's still leaking. I'm out of ideas.
I'd be glad to help out but all I've done produced no results so you are in for a major headache with this leak.
Old 06-19-2007, 06:40 PM
Re: Wet floor
Another way to find out if the door seals are the culprit is to take a piece of paper and see if it slides easily through the seal with the door closed. Window obviously down.
DepecheFan, your GA have a sun roof too I take it ?
I just used some puty stuff behind the areas of my door seals that I thought were leaking.
So far, I've had dry floors for almost a year on both GA's
Old 06-19-2007, 07:32 PM
Jmoney3318's Avatar
Re: Wet floor
yea i gotta try some of these ideas and try to find out where this is coming from and i have a feeligns its goin to be a headache like u said. but it was so crazy like it was puddled water in the coner of the rug and stuff shit was trerrible.. but yea i got sum stuff to figure out, thanx for the ideas guys =D
my Cardomain
-Xero is my hero--
mods:
Old 06-20-2007, 08:13 AM
GASE 95 GASE 95 is offline
Re: Wet floor
i had a similar problem except it was only my front drivers side floor that was wet...not the back. The seal between the floorboard and the firewall (behind the pedals) had a hair-line crack in it. It was almost invisible. I sealed it back up and problem solved.
Also, I had my windshield replaced a few weeks ago and i noticed water dripping in through the top side of the drivers side door seal. I looked at it and found that the seal was "lipped" under itself. I "unlipped" it and its fine.
might also want to check the trunk seal. I opened my spare tire compartment and found it 3/4 full of water. The tire and the jack were completely submerged. I ended up drilling 3 holes in the bottom of it to prevent it from pooling like that again
just a few things to check.
Old 06-21-2007, 05:18 PM
95 Grand AM GT 95 Grand AM GT is offline
Re: Wet floor
I had the exact same problem and I just finished fixing it the other day. On the grand am, or at least on my '95 grand am, the water runs down the drains on either side of the windshield and down towards the center under the hood rather than just straight down like most other cars. On my car, the problem was that the seal on the firewall was shot at the top and it had also a small hole, about half an inch in diameter, rusted through it. I drilled out the metal to remove the rust and covered it with bondo body filler. The car has been dry since then, but it took me a while to figure out where the leak came from. Also in finding the leak, there is a black rubbery material with a gray spongy backing covering the firewall. I had to cut that away to find and fix the leak, however you can't see it after i put the cover back on down there. I can take pics or even a video if you would like me to just email me if you want them or have any other questions about it.
P.S. My car also only leaked when it rained and after you try to fix it running the hose down the windshield is a good way to test it after whatever you used is dried.
