Go Back   Automotive Forums Car Chat > Ford > Falcon | Fairmont | FPV
Falcon | Fairmont | FPV Australian and American versions. Includes the XR6 and XR8 as well as FPV models like the Typhon.
Old 06-19-2007, 02:01 AM
Noobira Noobira is offline
XF Fairmont Heater doesnt work
Hi guys,
My XF fairmont heater has stopped working properly, i watched the valve on the heater hose and it opens and shuts as you turn the temp knob on the dash, but the air doesn't get any hotter. Its freeezing as normal when the temp knob is on cold and then when turned to full hot there is a little heat usually dissapated by the fan but not like it used to be.
Any ideas would be really helpful - I just hope I don't have to pull the dash apart cause I hate that job lol
thanks,
tonyopcorn:
Old 07-23-2007, 10:34 PM
sparkeykev sparkeykev is offline
Send a message via Skype™ to sparkeykev
Re: XF Fairmont Heater doesnt work
Originally Posted by Noobira
Hi guys,
thanks,
tonyopcorn:
Check the vac hoses are still attached in the engine bay down the firewall on the left hand side small plastic hose goes into a rubber connector
Old 07-24-2007, 06:33 AM
Davescort97 Davescort97 is offline
Escort guy
You have 2 heater hoses going through the firewall. Disconnect them from the heater box and back flush the heater core with a garden hose. You will get a lot of gunk out of your heater core. If that doesn't work replace the thermostat. Is the engine warming up?
