Old 06-18-2007, 08:24 PM
SnipesXxX SnipesXxX is offline
Drain and fill radiator?
What steps do I need to take to drain the coolant and fill it back up? Also where is the drain plug on a 2000 Grand Am SE 2.4L? Should I put Dex Cool back in it? If someone has a link to some info on it that would be great aswell.
Thx
Old 06-19-2007, 12:01 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Re: Drain and fill radiator?
I'm sure if you do a search in the grand am forum,
you'll find many threads answering your many questions.
Here try this....
http://www.automotiveforums.com/vbul...archid=1930179
1999 Grand Am SS 3.4 OHV
Old 06-20-2007, 10:33 AM
the link says:
Sorry - no matches. Please try some different terms.
I tried searching for dex cool and coolant without much luck.
Old 06-20-2007, 11:44 AM
jem270's Avatar
jem270 jem270 is offline
I did a search here using dexcool and found lots of stuff. You could always google it.
I swapped mine out to the dual purpose green stuff. I think it is personal preference. Some switch some don't. Spend some time surfing here. You will learn a lot. I have.
1997 Grand Prix SE, 3.8 (L36), 4T60-E (auto) M13
2002 Grand AM SE1, 3.4 (LA1), 4T45-E (auto) MN5
2003 Silverado LS, 5.3 (LM7), 4L60-E (auto) M30
1988 Ford Bronco EB 5.0 (AOD) manual BW1356 & hubs
Old 06-20-2007, 12:20 PM
I still don't see anything that shows step by step(where the drain plugs are) and stuff. I may take it to a mechanic and have it done. Could someone tell me if $180 is a fair price for labor and parts for a flush and thermostat change on a 2000 GA 2.4L with 145,000 miles?
Reason I am looking at getting it flushed and thermostat changed is because when idling the temp wants to creep up a bit past 200 where before the spring it didn't do that. Fans work and all so I don't know what else the problem could be. The coolant afaik hasn't been changed along with the thermostat.
Old 06-20-2007, 01:56 PM
look for radiator flush or radiator drain , I found 3 pages.
Radiator Flush Help-
'98 2.4L: Engine overheats in warm weather when stopped
Coolant System Flushing
Old 06-20-2007, 02:21 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Thx
It is recommended that if your vehicle came from the factory with Dex Cool you should continue to use it. Basically Dex Cool is different from the green antifreeze which is ethylene glycol based. Dex Cool is an Organic Acid Technology based coolant or OAT. Each coolant has their own separate protection packages designed to meet the needs of the engines they are in. Dex Cool is designed for the newer, modern engines with different metals and technology. Substituting the green coolant will not give you the proper protection your engine needs and may cause issues "down the road". The interval change for Dex Cool has been lowered from the original 5 yr/150,000 mile period to that similar to the ethylene glycol based coolant. I change mine every couple of years or between 30 to 40,0000 miles.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
