Old 06-18-2007, 06:24 PM
brad2886 brad2886 is offline
91 accord automatic tran. problem
Hello... let me try to describe this:
When I put my car into reverse or any forward gear, the rpms drop very low and there is a very noticeable squeal coming from under the car(doesn't sound like a belt, but more of a metal on metal grind). If I'm lucky enough to get the car moving without it dying, it shifts from 1st to 2nd and so on just fine. Any ideas on what this could be? I checked the fluid levels for the tran. and its level is where it should be at and the fluid is a nice red color. Any ideas?
Old 06-20-2007, 07:29 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: 91 accord automatic tran. problem
Let me ask you this....once moving, does it idle OK in gear when you come to a stop again, or does it try to die?
So is it just on initial engagement, or anytime in gear at idle?
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-20-2007, 01:22 PM
It idles fine. It only wants to die on initial engagement.
Old 06-21-2007, 08:01 AM
Damn...that's not what I wanted to hear...
I've seen a few GM's do something very similar, it was the torque convertor lockup dragging, making noise and loading the motor when you try to put it in gear. But I'm sure there are other things it could be.
I think a shop diagnosis is in order. Wish I had better news.
...empty gun rack.
Old 06-21-2007, 02:44 PM
Ya I'm taking it to the shop that had the transmission put in. About 20k miles ago it had a new or rebuilt tran put it, not sure which. So maybe it's still under warranty. If not, no big deal. The car only has about 110k miles on it so it's worth fixing, I think.
