What's the best oil?
After hearing that Mobil1, the oil that I've used for years, changed their formula and it's no longer a true synthetic (even though the price continues to rise) I'm thinking of looking around and might change brands.
So..... what's the best oil? Obviously that question entails so many variables that a perfect answer can't be expected. Different oils perform better for different people. I just want to here what you guys use. So, what's in your crankcase? |
Re: What's the best oil?
I like the King picture better.
"If everyone is thinking alike, then no one is thinking". - Gen. George S. Patton Jr. |
Still puts a grin on your face, though. I use Valvoline. No reason why. It gets the job done.
1998 Chevrolet Blazer LT (95% stock) Pioneer AVH-P7500 DVD receiver 12" Alpine Type-R in a sealed box PIAA Super Plasmas GT-X bulbs PIAA Xtreme White bulbs K & N drop-in filter ![]() "Melo" and "AI". Enough said.
Usually castrol. It's readily available and a pretty good price.
I hear KY is a pretty good lube - do you think it'll hold up to a 4.3?
2004 Explorer XLT 4.0L 4x4 1998 Ranger Supercab 4x2 3.0L Anyone who said There Is No Such Thing As A Stupid Question never worked in a grocery store! Come visit me on www.faceforums.com |
Amsoil maybe? I am probably going to stick with Mobil1 for a few more oil changes and see what happens. It has gotten me to 155K+ miles so why change now?
2002 Pontiac Gram Am K&N Air Filter Mobil1 5W-30 Extended 15K 2 JL Audio 12" Subs Sealed JL Audio Box Coustic 400 Watt Class D Mono Amp Pioneer Head Unit 50X4 MP3, WMA, AAC Super Tuner Polk DB750 6.5" all around Yankees Suck!!!!!!!! |
Uranus All Natural Oil.
Environementally Friendly. No synthetic adders, ALL NATURAL, no By-Products wasted in Manufacturing. By Uranus Corporation. Taking Over The World.
It's my opinion, don't take it personal. '04 T&C,'01 Blazer ZR2, '97 Blazer, '97 Sunfire, '85 Vette, '79 Civic, 94 FLSTC |
Did not know they had changed. I have been using Mobil 1 for years, if you get the perfect answer let me know.
2000 Blazer 4.3L; 4WD; 4Dr 1998 Olds Intrigue 3.8L 2003 GMC Sierra 1500HD Crew cab |
This question can usually cause some colourful debates.
In my opinion, I think amsoil is one of the best out there currently. I currently am running Amsoil 10W30 in my truck. I use the group IV pao base synthetic oil that amsoil sells. Mobil1 use to be my only choice, but now that has changed. Not that the oil is bad, but the chemistry of the oil has apperently changed, and the price does not reflect that. Mobil1 use to be a group IV pao oil, but that has apperently now changed, like Castrol has done long ago. The only castrol I would use would be the 0W30 german oil, as that appernerently is still a group IV oil. Another oil I am considering using is the shell rotella 5W40 synthetic. Apperently that is another very good oil and has a lot of zinc in it, which I personally believe helps tremendously. I always use the GM EOS as they call it(Engine Oil Supplement) at least everyother oil change. Again, it has a good supply of additives, loads of zinc, which I think really helps the longetivity of the engine. Either way my choice of oil right now is Amsoil, very good oil and your getting a real synthetic oil. |
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
I am not telling what people to use, or not use. I am merely telling others what I use/do. I know this is a debated topic all the time. I use EOS because I find the boost in zinc content in my oil has helped both my past and present vehicles run better, by reducing engine wear. Heavy duty motor oils, diesel engine oils have much more zinc content as it protects and reduces wear in the engine. Automobile engine oils don't have as much zinc becasue zinc has been found to harm catalytic convertors. In all my experience, with many vehicles, and many, many of thousands of miles, I have never lost a convetor due to any contamination of oils etc. If anything, as a result of tighter clearences in my engine as milage accumilates, I have probably polluted less as I don't have to ever add any oil between oil changes, and I run longer oil change intervals too as I am more confident that the oil will last.
I was told long time ago, by an fellow tech (I would quailfy him as a master mechanic in my opinion, 35+ years experience at the time) that if you ever want to know what kind of oil is really good out there, ask a fleet manager what they use, e.g. taxi company, etc. |
First off, I want to set the record straight by saying I understand that you were merely stating what you use in your vehicles and not telling others what to use.I was just questioning additive usage in general hoping to get the word out to other members who may read these posts thinking that additives are the "cure all" to their problems when in many cases it is not. I used to use additives all the time thinking I was doing my engines good, when in actuality it was either doing very little or nothing at all. When I first started in the Automotive Industry, I worked in some auto parts stores and parts departments. Too many times I saw people buying different additives for different problems with their cars that something else could solve their problem, such as a tuneup, fluid change, or filter change among others. There are "additives" on the market that are little more than snake oil and do very little in the way to help "cure" any issue. It's a means for some corporations to make money on unsuspecting car owners. If people just took care of their vehicles better and did the maintenance at the required times, the need for "additives" would be significantly reduced. I have even gone out on a limb before by saying that if more people started with synthetic oil for their vehicles, we could use less oil overall because of the extended change intervals, and there would be less oil to dispose of or recycle, or handle by other means. I was hoping by my post to let people know that additives aren't the solution all the time to the problem. I see a lot of posts on this site asking about additives when there might be a better alternative fix to the issue.
I know this thread has gone a little off topic , but maybe we can get it back to the question at hand. Quote:
I worked for the City Transportation Co. (bus Company). They used Bulk Delivery 30 weight oil in the diesel buses. Purchased it 2000 gallons at a time.
I was thinking of filling my crank case with engine restore and lucas oil and just to see what happens!
Kidding
lol @ Uranus.
Thanks for the input guys. I've been looking around bitog, too. Looks like M1 is still a good oil. I've heard that they recently came out with a high mileage oil that is stacked with a strong additive package, so I'll probably give that a shot, I just don't like the idea of knowing that they have increased their profits, at a cost to the quality of the product that they sell to their customers. I also think it's pretty damn hypocritical considering that they were outraged that other companies were doing the same thing. BTW just for the record, blazes9395 is a respected member of this forum and has shown countless times that he has advanced knowledge of all things automotive, including engine lubricants. He is completely capable of deciding how much and what kinds of additives are safe to use. |
