Old 06-18-2007, 01:33 PM
Evsman Evsman is offline
1999 454 high idle
I recently acquired a 1999 K-3500 with a 454 and manual transmission. I am experiencing DTC code P0507. Whenever I shift, the throttle hangs at about 1700 rpm with the clutch pushed down. Eventualy after a period of about three seconds it will begin to slow back down to around 1200 rpm. After a long time it may even settle down to 800rpm. It obviously shouldn't be hanging so long at these rpms. What do I need to do about this?
Old 06-18-2007, 02:09 PM
2000CAYukon 2000CAYukon is offline
Re: 1999 454 high idle
Usually due to a vacuum leak. Could be intake gasket, TB gasket or vacuum hose.
//2000CAYukon
Old 06-19-2007, 06:17 PM
So how does one go about finding a vacuum leak? Where do I start?
Old 06-19-2007, 09:19 PM
777stickman 777stickman is offline
Use a spray can of carb or brake cleaner with the engine running. If there is a vacuum leak the rpms will change. Could also be the IAC valve, throttle linkage (binding), bad throttle body (binding).
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
