Go Back   Automotive Forums Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 06-18-2007, 12:44 PM
listenloud listenloud is offline
Air Bag Light On Intermittently 99xj8
1999 XJ8. The air bag light comes on sometimes, and then goes off. Any ideas what to look for? How do you diagnose the air bag on a jag?
2008 Honda Civic EXL - Daily Driver
2000 Silverado 1500 LT - Boat and Haul
2005 Honda Pilot EXL - Wife and Kids
1997 Ford Mustang Cobra Convt. - W/E
Old 07-10-2007, 07:25 PM
topdaawg topdaawg is offline
Re: Air Bag Light On Intermittently 99xj8
Probably The Clock Spring. This Is Very Common On Xj8's.
Old 07-11-2007, 09:44 AM
How do you replace it? How involved is it? I know it's in the steering column under the wheel. Any help is appriciated. Thanks.
Old 07-15-2007, 11:49 AM
It is pretty east to replace. You need to remove the airbag, which I believe has two 30 tork bolts holding it from behind, then you can remove the steering wheel. You will also need to remove the steering column covers that are right behind the steering wheel. They are just held in place with a couple screws from underneath. Finally you need to remove the knee bolster below the steering column, becuase there are some wires behind there that connect to the clock spring.
Old 07-26-2008, 12:28 AM
djagman djagman is offline
more often then not it is the spiral cassette.call the dealer
Old 07-26-2008, 12:48 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
