Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 06-18-2007, 10:21 AM
sizzilianone sizzilianone is offline
AODE Transmission Shudder
I’ve a 97 Mercury Grand Marquis, 80,000 easy miles, all driven by my 82 year old Mother. From other posts I gather it’s an AODE transmission. It seems to generate this shuddering feeling about 40-45 mph under easy acceleration. That’s where it starts. It also does it at expressway speeds up to about 70, always under easy acceleration. Hard acceleration, no shudder. Coasting, no shudder. If the OD is turned off, it seems to alleviate the problem somewhat, although it doesn’t cure it completely. If you accelerate really easy, it may shudder for several seconds. If you go a little harder, it may only bump two or three times, in a second or so. I’ve seen other posts recommend flush and clean, one other mentioned a speed control, but it kind of sounds like low line pressure to me. Any thoughts?
Old 06-19-2007, 12:29 PM
reekor reekor is offline
Re: AODE Transmission Shudder
If the transmission fluid has't been changed for a while get that done. If you notice no differance with that done, have a look at your spark plugs and wires.
His, 96 Limited, 5.2 Magnum, Magnaflow CatBack System, HID Head & Fog Lamps, 242 T-case swapped , Rear Trac-Loc. Chrome grill added to match the wheels.
Hers, 96 Limited I6, 242 T-case, HID Head & Fog Lamps.
Old 06-22-2007, 06:57 PM
RexNfx400's Avatar
RexNfx400 RexNfx400 is offline
After 1996 this transmission's name changed to 4R70W. Which is "basically" an AODE.
This syptom is common, as the fluid ages you can get a shudder while the torque converter clutch is modulated on/off. Basically, the clutch is made to slip on/off. So fluid integrity is important.
As already posted:
I would recommend: pand drop, filter change and drain the torque converter. That shoud take care of it. If all thats been done already... Then maybe, the torque converter is defective or the engine is misfiring. It usaully takes a few miles after the fluid exchange to know if it helped or not.
Old 06-25-2007, 09:53 AM
Thanks gentlemen for your observations. It sounds like you've hit it right on the nose. I'll let you know, following change. Thanks again.
Old 07-26-2007, 07:44 PM
senior Citizen senior Citizen is offline
I had the same problem with my 97, it was a common problem: The dealer replaced the transmission fluid and installed a transmission cooler: no charge
