Old 06-18-2007, 10:12 AM
baysicc707 baysicc707 is offline
whats the best way to wire subs in a 96'?
what is the best way to wire your subs in a 96 park ave? ive herd many aproaches, but when i went to do it i was lost as hell...anyone have any good ideas or tell me how you did it so it dosent look all tacky...
Old 06-18-2007, 08:18 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
Re: whats the best way to wire subs in a 96'?
First, every wire (RCA cables, amp power cable, REM power, etc) is trailed on the passenger side. Trail everything underneath the plastic floor panels under the doors (they're screwed in place in my car, but I've seen others with clip on fasteners) Inside the trunk, at the very back on the passenger side is a large grommet with your antenna cable and power antenna wires coming through it. Either remove the grommet or do what I did and cut a slit in it with a knife. Take your wiring and pull back on your back seat, passenger (right) side. If you have fold down seats that'd make it even easier. Slide the wires through the grommet/ hole in the sheet metal that goes into the trunk. Feed the wire until it is totally hidden behind the seat. Voila, you've got your wiring all set for your amp and subs.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
