Old 06-18-2007, 02:56 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
ECU engine kill?
So I was wondering, let's say hypothetically one were to try to race a GTO on the highway and misshift 4th and hit 2nd instead at ~110 mph, one then pushed in the clutch, and the engine died. In this hypothetical situation, does the ECU kill the engine when it sees wayyy more RPMS than it should?
(yeah...i almost shit my pants cuz i was sure I blew my motor or at least jumped the timing belt, had to have been like 12k rpms. First time i ever missed an upshift. Pulled off the side of the highway afraid to restart it, but finally tried and it was all fine)
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 06-18-2007, 11:31 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: ECU engine kill?
nope, ECU will not kill the engine or limit the revs b/c that's a mechanical over-rev.
when you dropped it to 2nd gear, did you let the clutch out? if so, mechanical over-rev = bad news for your heads. i would seriously not drive the car before you 1) check the timing, 2) leak down test, 3) compression test.
mechanical over-rev usually means bent valves.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 06-18-2007, 09:42 PM
Yeah I let out the clutch, I was racing lol, even hit the gas too...only for a split second...the instant I felt myself go forward instead of backward, I slammed the clutch back in and coasted...that's when I noticed the engine had shut itself off. I'm thinking the ECU saw me past redline, cut the injectors, and because I had let off the gas and slammed the clutch in, they didn't turn back on and it just died....unless it has some protective thing that kills the engine when it sees that much RPM.
I thought for sure I had at least jumped timing or seized the motor...but I must have caught it in time, because once I got the courage to try starting it again, it ran just fine. No noises or problems.
Old 06-18-2007, 10:01 PM
Linebckr49's Avatar
unless you hit fuel cut, but even then i don't think the ECU shuts the engine off, rather the car will just buck violently until you back off the throttle.
still, for piece of mind, if it was me, i would check timing, and perhaps do a compression and/or leak-down test.
93 3000GT base
Old 06-19-2007, 01:09 AM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
yea best thing to do is check things out before you begin to drive it as normal again
Old 06-19-2007, 08:08 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
There is nothing mechanical or electrical thay would cause teh car to shut itself off. Most likely what happened is when you pressed in the clutch the RPMs fell so fast that the IAC and ECU couldnt catch up and keep the car running.
