Old 06-18-2007, 12:10 AM
harleypanrider harleypanrider is offline
Send a message via Yahoo to harleypanrider
93 2500 clutch ajustment ?
just bought a 93 silverado 2500 4by4 350 5 speed manual 215000 guy said was overhauled at 200000 and said heavy duty clutch installed at same time clutch seems to push in real hard compared to other ones ive driven and grinds going into gear when at a stop but not as bad once your rolling doesnt seem to slip tho is there any ajustment to these or did the guy fib to me about new clutch also why would it push in hard i checked the little resavore under hood for clutch it was full
Old 06-18-2007, 08:38 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 93 2500 clutch ajustment ?
A HD clutch will push hard.
Does it have a outside slay cylinder with a adjustment on ot.
How much free play in clutch pedal?
Have you tried to bleed the clutch system?
MT
Old 06-19-2007, 12:15 AM
thanks for reply stepping on pedal id say it goes half way to floor about before i feel anything on the pedal yea slay cylinder is on pasengers side outside of trans was about dark when i looked at it didnt realy see if theres a plase to ajust it and no i havent bled it what is procedure for doing that? i took radiator out today and had a new tank crimped on wants to blow antifreeze back out but doesnt overheat and blows hot air out of heatewr i noticed radiator sits lower then moter so hope thats all it is ive heard you have a bugger of a time getting air out of them hope thats call it is
Old 06-19-2007, 08:24 AM
MT-2500's Avatar
AF - Advisor
Bleed first.
Push down pedal and open the bleeder on slay cylinder a couple of times.
The gravity bleed. Fill clutch cylinder full and ope bleeder and let it drain threw some.
MT
MT
Old 06-19-2007, 11:28 PM
thanks that seemed to help a little thermostat took care of blowing water out took it for a spin tonight and heat gage goes quarter way up and levels off right where i like them to be beat new bushings and pins in drivers door so it closes like it should now change oil and tune up i guess it runs like shit jerks going down the roadlike its going to dye anyhow thank you for the help
Old 06-20-2007, 08:40 AM
MT-2500's Avatar
AF - Advisor
You are welcome and thanks for posting back how it went.
Give it some tender loving care and it may run forever.
And always feed it Good AC Delco plugs and parts
Good luck
MT
MT
