Old 06-17-2007, 11:35 PM
BlueCaprice BlueCaprice is offline
Oil light and slight knock after 30min of driving
Hello everyone. I just changed the LIM gasket on my 96 3.8l Windstar, and now, on really hot days after driving for maybe a half hour, the oil light comes on and the engine kinda ticks or knocks very slightly. I haven't listened to it to well cause when it happens I'm afraid to leave it running. I've changed the oil three times in six days to make sure the crank case was clean of any radiator fluid but it hasn't helped. Anybody know what might cause this?
Old 06-18-2007, 07:53 AM
12Ounce 12Ounce is offline
Re: Oil light and slight knock after 30min of driving
I wouldn't drive like that ... nothing but bad can come of it.
Probably something (trash) is sucked up against the oil pick-up screen. THe pan will have to come down for an inspection.
Old 06-18-2007, 09:40 AM
If you don't find the screen plugged-up, you'd better check the crankshaft and rod bearings.
Old 06-18-2007, 02:57 PM
Thanks so much for the reply. I'm hoping it might be something plugged up like you said, however when I checked the oil, it seemed very hot to me, so I also thought it might be bearings. If the bearings are bad, could they be quiet when the car is cool, but causing enough friction to kind of "cook" the oil and cause problems? Before I get the oil light, I can't even hear the engine running. Again it was a very hot day, but I never noticed this in my other car. I will drop the pan like you said and hope for the best, but I won't be able to get to it till at least the weekend so I want to prepare for the worst.
Old 06-18-2007, 05:26 PM
The oil is a bit thicker when cool, and thins when warmer ... I suspect this is why the noise comes and goes with high temps.
The oil may be getting hot because of bearings ... but more likely because of piston blow-by, heating up the whole crankcase area. How many miles are on the engine ... and what kind of maintenance history does it have?
Old 06-18-2007, 08:38 PM
I think the van has about 109,000 miles on it. The oil changes were pretty regular. It' s been through 1 transmission. When the car died from the blown gasket, I went to get it off the side of the road, and the crank case was full of radiator fluid. I drained it and let it sit draining for a many days. When I pulled the LIM I could actually see where the gasket had broke and the fluid was pouring in so I changed the gaskets and put it back together. I gave it 3 oil changes to flush any fluid out. Thats about it as far as History. The Check engine light is on, but that has been on for 7 years. The engine always ran very good, and does still, till the oil light comes on. I haven't check it today. I want to drop the pan before I run it anymore.
Old 06-18-2007, 09:34 PM
Coolant in the crankcase ... that's not good.
Old 06-18-2007, 10:42 PM
Yeah I know. I think it happened all of a sudden though cause the car ran really really bad when the gasket crapped out. I drove it 3 blocks home after letting the motor cool and I didn't run it again till the new gasket. I was hoping the motor might have survived any serious damage.
Old 06-18-2007, 11:00 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Hello
Antifreeze eats bearings. What weight of oil are you using? Which gasket blew?
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 06-19-2007, 12:10 AM
The gasket that blew was the Lower Intake Manifold gasket. I used 10/30 the first time and 10/40 the second and the third. I put in a bottle of STP on the last one. I was planning on doing a few oil changes to make sure everything was flushed out so I bought the cheapest oil they had, and was gonna end off with a good synthetic or something of the appropriate weight.
Update - I started the car today. It was ice cold, and now the oil lights stays on all the time. It shakes a little too. I didn't run it for more than maybe 15-20 seconds at a time but I started it a few times to see if the light would go out. It didn't. We'll see what happens when I drop the pan.
Old 08-13-2007, 08:22 PM
Well the pick-up screen was VERY VERY clogged. I'm pretty sure It was my fault. While changing the LIM gasket it started to pour, so I went inside. When it had stopped, a bunch of berries and flower pedals had fallen from a tree onto the engine. I vacuumed it all up as best I could with my shopvac, but aparently some got into the crank case. Anyway it's running strong again. Thanks for all the help.
Old 08-13-2007, 09:17 PM
wiswind wiswind is offline
It is great to hear that you are back on the road!
Thanks for posting back on what ended up being the problem.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
