Hoods and Engines?
"What you don't see is why you see my tail lights!!!" |
Re: Hoods and Engines?
That TPI 305 will give you the power and torque of a 350, great swap to keep it economical.
What transmission do you have? TH2004R or 4L60(TH700R4)? For the cowl hood, I've not personally ever seen one for that car, but you can modify a hood yourself if you're so inclined.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
I have a rebuilt 700r4 that I built up for solid shifts and a little more power. The next thing to to is redo the rear end to 3.42:1 heavy to handle the power coming down( I hear tale of the 3.07 rears shattering over any major power increases).
this is what I hope to end up looking like........Kind of. http://www.popularhotrodding.com/eve.../photo_01.html |
I smell a mechanic silicon.......... say how would you "make" a cowl hood without a sheet metal master? The only parts that I could find to modify the hood are PLASTIC, I will never cheapen my baby that way. Any help would be great, and thanks for responding.
"if you aint cheatin you aint tryin" |
Anyways, you can fabricate a hood yourself if you have the wherewithall to do it. Depends on what you want to do. As for what I am sure is the comment about my 3.08 remark above, factor in that is exactly what I am running - with a mildly potent 350, not a 305. My engine specs higher all around than a 305 TPI does (which specs on par with a factory 350 TBI). Then again, my car has the police package so it's a bit more robust than a garden variety Caprice - but then my old '72 Impala had a 7.5" 2.56 gear axle and it lived many years behind the 350 in the car, so these rear axles are a bit more robust than you give them credit for.
Two blown out knees latter metal work I am afraid is outside my "abilities" however I do need a shower LOL. Seriously though I think I will start will a junkyard hood and see what can be done.thanks for the info on the rear, I thought the caprice for 88 had a 307 rear end .......of course that is what I could find, and lets face it sometimes what you find is not right.....
"I like to build to break........sometimes" |
http://www.usbodysource.com/ for the hood.
CD 1991 W41 #142 1989 Caprice 9C1 1997 C1500 1997 Bonnie SE 1998 Olds 98 LS Recently updated: http://forums.b-body.org |
I am assuming that you are reffering to the impala as a crossover part for my 88 caprice? At any rate this will shave wieght and give the clearance that I so desparately need to vent underhood heat......lets face it with that tight over clearance to the engine there is alot of trapped heat no one wants!
"Make thier jaw drop without showing" |
If you go to their 77-96 Impala section, they list a hood for the 80-90 cars. Impala/Caprice what ever they want to call it, it will fit.
