Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 06-17-2007, 01:56 PM
Sidewinder0976 Sidewinder0976 is offline
Cool Distributor or Intake
My 1990 Caprice 305 t.b.i is leaking oil from the back of the engine, it is running downthe right hand side of the tranny and block. and dripping off right near the Cat. Converter Is this an intake gasket leak. I also was curious
if it was possible to be the distributor seal, it is to tight to see perfectly what it is. Any suggestions???
Old 06-17-2007, 02:03 PM
marc-o-matic marc-o-matic is offline
Re: Distributor or Intake
It could also be the valve cover gasket.
Your best bet is to clean off effected area
and watch(w/mirror?)where it is coming from.
HTH
Old 06-17-2007, 08:57 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Mine is leaking a bit out of the rear seal on the intake. I suppose one of these days when I'm not too lazy, I'll rectify it. Until then, I'll put a quart of oil in it every other month and clean it then.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-20-2007, 11:40 AM
Mine smokes like crazy and is covering the whole back of the tranny as well as the starter motor. The smoke is from the cat. converter burning it off. Just was curious.
