Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 06-17-2007, 12:32 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Question Head Lube Question, again...
Hey all;
Ok I'll be building my head tonight and installing Tuesday/Wednesday. Question about lubing. I need to oil the actual valves, like where they go inside the head right with oil? Then the valve clips or whatever you call them need oil or greese then also? Then the lifters need to be soaked overnight in oil. Then on wednesday when I do the swap I know the cams need to greesed up, but do the rockers need anything or no? Sorry for quick question, working from phone.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 06-17-2007, 01:12 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
Re: Head Lube Question, again...
Well, when I did mine, I lubed everything up with oil first, then drained a few quarts from the block and poured new oil all over the entire valve train. It seemed to work fine for me.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 06-17-2007, 01:27 PM
david-b's Avatar
Dave is THAT guy
But like when I'm specifically building the head (off the block) what all do I oil? Like the valves, shouldnt' have to do the springs right?
75 Monte Carlo
Old 06-17-2007, 01:41 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
You don't necessarily need to oil everything while you're putting it in, just make sure all of the components that have friction get some lube. I use moly lube instead of oil just because it sticks better and doesn't make such a mess. Smear some on the valves when you put them in and then make sure you get the cam journals and the camshafts all nice and lubed up, but the rest of it (springs, retainers, etc) you don't really need to worry about.
95 Talon TSI AWD
97 Eclipse GST
Old 06-17-2007, 01:54 PM
david-b's Avatar
Dave is THAT guy
Sweet. Like I said, I'm building it up tonight, getting everything prepped, and then swapping on tuesday or wednesday FINALLY! Actually excited about it. I hope that little piece comes in by then, but if not I'll have to ghetto-rig up something.
75 Monte Carlo
Old 06-17-2007, 01:56 PM
I'm guessing thursday or friday. You should have told me you needed it by then, I would have priority mailed that bitch.
95 Talon TSI AWD
97 Eclipse GST
Old 06-17-2007, 02:05 PM
david-b's Avatar
Dave is THAT guy
It's all good. Don't worry about it. I may be able to use the one from my current IM, but I may not want to risk cracking that one off too. It's no biggy really. Thanks again for sending that.
75 Monte Carlo
Old 06-17-2007, 04:24 PM
95 Talon TSI AWD
97 Eclipse GST
Old 06-17-2007, 07:33 PM
Thor06's Avatar
Jizzed In My Pants
Jesus you two, get a room already.
But even if you dont really need to oil everything, it sure as hell wouldnt hurt anything.
Old 06-17-2007, 11:34 PM
david-b's Avatar
Dave is THAT guy
Maybe if we ignore him, he'll go away.
Got 6 damn valves done. Shit I can't make any tools to make this go together easy. Nothing I have or can throw together is making a good compressor. I know about that tool with the O2 socket welded on but I dont have a welder. I've been using a giant C-Clamp, and then 2 smaller C-Clamps stacked on top of each other on top the the spring. The big one is then being used to push the smaller ones down. Works good, but once you get the one in (where's theres 2 in a section), the pieces from the smaller C-Clamps get in the way of the springs then. Complicated. Have to try to finish this tomorrow.
75 Monte Carlo
Old 06-18-2007, 01:11 AM
I took a socket (13/16 i think) and cut a chunk out of the side and used that with a C-clamp and it worked freakin awesome, took a 1/2 hour to do all 16 valves. And a tiny ass magnet works wonders for placing the retainers where you want them too.
95 Talon TSI AWD
97 Eclipse GST
Old 06-18-2007, 10:37 AM
david-b's Avatar
Dave is THAT guy
See I don't have anything to cut out the side of a socket. That would take days for me to do that.
I actually just came back from ACE hardware and bought a piece of pipe or something that would fit perfectly on top of retainer, it's decently long, and has a large hole on the side of it, halfway up the pipe. Should work good, however I'm at work from 9-8, so I can't test it until later. Should work though.
75 Monte Carlo
Old 06-18-2007, 08:25 PM
Well what the hell kind of mechanic are you!! Do you want me to mail THAT to you as well? Haha.
95 Talon TSI AWD
97 Eclipse GST
Old 06-18-2007, 09:10 PM
david-b's Avatar
Dave is THAT guy
I'm the lazy kind. I jsut go to the hardware store and find something to ghetto rig up. I rock like that (even more so than Brian).
75 Monte Carlo
Old 06-19-2007, 08:21 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
do you get hit in the nuts with air hoses too?
I'd pay to see it
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
