Old 06-17-2007, 09:11 AM
bmw490 bmw490 is offline
94 PA starts and dies
starts runs about 5 secs and dies, won't restart until key is turned off, then back on. Not losing spark but losing fuel injector pulse after motor starts.
Old 06-17-2007, 09:22 AM
maxwedge maxwedge is offline
A990 racer
Re: 94 PA starts and dies
Welcome to AF, are you sure no pulse, this not a loss of fuel pressure at the rail?
Old 06-17-2007, 10:11 AM
Thanks, and yes losing pulse, can see test light flashing when motor is running, then quits and motor then dies. Fuel pressure is good 45-50 PSI.
Old 06-17-2007, 01:01 PM
A990 racer
It would seem that as this happens you probably loose spark, BTW good check procedure. Try and get a scanner on it and see if you have cranking rpms when it won't stay running, also look for poor connections from crank sensor to the ign module, suspect either one here, get a test lite on the pink wire at the icm see if it looses power as it dies.
Old 06-17-2007, 02:41 PM
Using homemade adapter and EFILive software for scanner due to being OBD1 w/OBD2 connector, RPM reads 800-1000 then drops to zero and motor dies, doesn't read when cranking after motor dies, but does have spark. Have already replaced crank sensor.
Old 06-17-2007, 02:54 PM
Have also tried new ICM, made no difference.
Old 06-17-2007, 05:47 PM
A990 racer
Look at all the harness from the icm to the crank sensor for one, there is no signal reaching the pcm from the sensor thru the icm.
Old 06-17-2007, 06:54 PM
metered wires from crank sensor to icm, all four check out, I don't understand why I read RPM when it first starts but not after that.
Old 06-17-2007, 09:04 PM
A990 racer
Loosing the cps signal, only way, or the pcm is bad.
Old 06-18-2007, 03:49 PM
steven david steven david is offline
having same problem,coding pass key error,vats system seeme to be the culprit,still trying after market module that bypasses vats system(just the fuel enable part)
Old 06-18-2007, 06:21 PM
I was able to borrow a pcm from another 94 pa from the car lot my son works for. started right up, ran a little rough but loaner was a ultra and I didn't swap proms. Thanks for the help.
