Old 06-16-2007, 11:32 PM
ss_chevy ss_chevy is offline
Valve seals
Have heard that valve guides can be replaced by removing spark plug, pressurizing cylinder with shop air, then removing valve spring and keepers, how do you compress the valve spring and keepers? Any help?
Old 06-17-2007, 02:54 AM
KiwiBacon KiwiBacon is offline
Re: Valve seals
I've heard of this method, but I don't recommend it.
Too easy to drop a valve into the cylinder, then you've gotta pull the head off anyway.
If your engine has too much valve/piston clearance then the valve will probably drop down just to far to have the spring and spring seat clipped back on it (if you happen to knock it or lose air pressure).
To answer your original question, compressing the spring will be done with force down from the top, whatever way you find easiest.
Old 06-17-2007, 05:46 AM
534BC 534BC is offline
Re: Valve seals
seals yes, but not the guides. Well, ok I have done a guide before without removing head.
Old 06-17-2007, 02:21 PM
UncleBob UncleBob is offline
AF -Advisor
Re: Valve seals
how you compress the spring depends on the engine in question. SBC, there's a tool that will compress the spring from the outside.....
Many engines the springs are recessed in pockets that make it very difficult to do this.
IMO, unless its an engine with known valve guide seal problems, the odds are you need to pull the head and freshen it up if the seals are shot. Replacing only the seals is a bandaid and very well may not make any difference, or will not last very long before the problem resurfaces.
life begins at 10psi of boost
Three turbo'd motorcycles and counting.
Old 06-17-2007, 06:19 PM
Re: Valve seals
You might be able to put on a set of umbrella seals to keep oil away from worn guides/bad seals.
