Old 10-29-2002, 07:56 PM
dominate9 dominate9 is offline
Send a message via AIM to dominate9 Send a message via Yahoo to dominate9
OBD II Accord distributor codes for H22 swap
I have a 97 Accord and I am in the process of putting in a 95 JDM H22A. I came across a problem yesterday. The distributor don't match up. The H22A has two plugs. One with two wires and the other plug with 7 wires. My Accord's distributor harness is one big plug with 5 wires. The H22 has an internal coil and the Accord has an external coil. I was told that I can wire the harness to the distributor. I have the color codes for the H22A but I don't have them for the Accord. Is the anyone out there that can tell me the color codes for the 5 wires on the Accord distributor and what they are for?
If there is anyone that swapped a 92-95 H22A into a 96-97 Accord, how did you overcome the distributor problem.
97 Accord EX Coupe (H22A)
_____________________________
18" Focal SD5
225/40/18 Kuhmo Ecsta Supra (712)
AEM Cold Air Intake
Walbro 255lph Intank Fuel Pump
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
Katzkin two-tone Leather
3 JL Audio 10W3s
Kenwood DPX-4020 Double Din
Old 10-30-2002, 07:47 PM
wagsaccordsir's Avatar
wagsaccordsir wagsaccordsir is offline
You will have better luck if you get the OBD 1 ECU (P13) then everything will wire straight in.. The Distributer; we used an MSD and got a MSD Blaster Coil and we took out the internal coil and threw it in the trash.. We then wired the MSD into the Distrubuter per instructions, and then slapped and external coil distributor cap on there.. Now I know I didnt answer you question but you dont have the P13 ECU and thats the only one that I know the wiring for.. I have a 97 Accord as well and just finished my H22 swap a few months ago... I love it, and I guarantee you will too... If you get the P13 let me know as I might be able to help then...
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
Old 10-30-2002, 09:19 PM
huh?
Hey, I do have a P13. I said that I have a 95 JDM H22A. Those are OBD I.
18" Focal SD5
AEM Cold Air Intake
HP Racing Exhaust
2.25 Custom Piping
Spoon Radiator Cap
3 JL Audio 10W3s
Old 10-31-2002, 08:11 AM
Kep Kep is offline
Send a message via AIM to Kep
Yeah we did my H22 swap and used the 4th gen accord harness. We had a similar problem. Of course my car is a 1990, so it's a diff generation, but here is what i remember...
The yellow with black and the black are power and ground. Then there is a green wire on the distributor that is the trigger wire.
I'm not exactly sure, maybe that helps though...heh..i'll check it out tonight and let you know...my car is at the shop right now.
-Matt
