92 Lesabre stalls after 10 minutes
I have a 93 Buick Lesabre that stalls after running for about 10 minuets. I replaced the fuel pump and fuel filter w/ no joy. When I turn the key to on position I get gas right before the injectors. I was able to get the codes 17 and 58 by grounding out pins a and b on the computer terminal and watching how many times the lights blink. I think it might be the camshaft sensor but am not sure if it is and how to test if that is the problem . Any help would be great
Re: 92 Lesabre stalls after 10 minuets
Code 17 is the Spark Reference Circuit. Basically it means that a signal is used by the PCM below 1200 rpm to better control ignition timing. I do not know if a lack of this signal could result in stalling. But it seems from my reading that neither code you have would result in stalling. Perhaps some more basic tests are needed: Fuel correct? Spark correct? Crank sensor working correctly? Ignition module correct? There are many things it could be and you need to see a good mechanic to find the true cause. |
Click Here for a CEL code description. A bad cam sensor usually will not cause a stall; however, it might cause the car to run rough. Code 17 indicates a failure of the spark reference signal to the PCM. Usually, the crank sensor will cause this code. BTW, this can cause stalling! It could also be the ICM or a bad coil. When the car is running, do you have any skipping or hesitation?
Knowledge can be communicated, but not wisdom! ![]() ![]() |
How do I go about checking the crank sensor?
Also No thier is no heistation before it stall out. It does sputter a little right before satlling but nothing in between. |
When you have an intermittent CPS problem, the best solution is to remove the crank sensor, place it in a pan of hot water and hook up your DVOM to watch the sensor's resistance as it warms up. (Check it all the way up to a boil). If it is a bad sensor, resistance will increase, until it suddenly goes open. (That is the point where your car will either, refuse to start, or simply shut down)!
Sorry for no response in a while I can only work on the weekends. I was able to gain some ground towards the trouble. If I leave the car run until it dies and will not start anymore I pulled out one of the plugs ,attached it to the wire, grounded it out and had my wife turn the car over, and their was NO spark. I know I did this right because I tried this before the car stalled and I had spark. I’m hopeing that someone might be able to help me narrow it down
Thanks |
The problem is is most likely the Crank Sensor or Ignition Control Module (ICM). Repeat your experiment but cool the crank sensor down with a stream of water from your garden hose. If it restarts after cooling the sensor then you found the problem.
How do i know where the crank sensor is???
Crank sensor is behind the harmonic balancer. Harmonic balancer is the pulley that attaches to the crankshaft. Lowest pulley on the motor.
This time she would not fire up at all even when it had been sitting for 4-5 hours. I sprayed water on the sensor becuase it has been a hot day but that did not work either how do I test the Ignition Control Module.
Thanks Bruce |
Best way to test the ICM is try it on another car.
You can also take the module to AutoZone and have them do a load test on it. Be sure to tell them to do it three or four times for best results!
Possible Crank Sensor issue
BTW, HOTZ, appreciated learning your suggesting for testing the unit. As I have a back-up unit, I'm going to use your test procedures.
1997 Buick LeSabre Limited, with Grand Touring Suspension (72,925 miles) with UIM/EGR Stovepipe leakage issues resolved/repaired & 1995 Saturn SL2 (498,125 miles) as of 6/19/07
Re: Possible Crank Sensor issue
