Old 06-16-2007, 11:22 AM
Corndog Man Corndog Man is offline
Bleeding Air From Coolant System
I have changed coolant in my 1999 3.8 a few times. I don't recall bleeding air from the system but I haven't had cooling problems. What is the procedure to bleed air from a Lumina cooling system?
Corndog...
Old 06-16-2007, 06:06 PM
TexasGuy TexasGuy is offline
Re: Bleeding Air From Coolant System
Nothing major, first week just be checking the coolant level, the air should come out by itself if nothing is damaged internally.
Old 06-16-2007, 10:59 PM
Thanks! I tend to do that fairly regularly on all my vehicles. I thought there may be a relief valve or something like that.
Corndog.
Old 06-17-2007, 10:41 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
There are bleeder valves at the thermostat and on the pipe above the water pump. Open both and fill the radiator directly. when they flow liquid, close both and run to operating temp. Shut off, let sit for ten miutes or so, then repeat fill with valves open again.
Sometimes they will purge themselves without bleeding, but if air is trapped overheating will be sudden and sometimes catastrophic, usually occurs as soon as the engine is running at higher rpm....I've seen them sit and idle at a steady temp for half an hour, then go over the top within a couple of blocks once driven...
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 06-17-2007, 04:49 PM
Thanks! Will give it a look
Corndog...
