Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 06-16-2007, 10:46 AM
blazberry5 blazberry5 is offline
1992 sc1 will crank but not start
Started the saturn recently. after about 10 seconds, it shut off. now, it will crank, but never starts. Not even sure where to start. any ideas?
Old 06-18-2007, 03:12 PM
samprix samprix is offline
Re: 1992 sc1 will crank but not start
Could be many things. Are you getting fuel and spark?
Old 06-18-2007, 08:09 PM
sickcallawayc12's Avatar
sickcallawayc12 sickcallawayc12 is offline
Timing, spark, and fuel. 3 necessary things to start a vehicle. Check spark first. What kind of plugs you using? How clean are the battery terminals? Are they tight? Solenoid good? Test the coil packs. Do you hear the fuel pump prime up when you attempt to start? Lots of possibilities.
1998 Chevrolet Blazer LT (95% stock)
Pioneer AVH-P7500 DVD receiver
12" Alpine Type-R in a sealed box
PIAA Super Plasmas GT-X bulbs
PIAA Xtreme White bulbs
K & N drop-in filter
"Melo" and "AI". Enough said.
Old 07-27-2008, 02:00 PM
davecrzy davecrzy is offline
I have this problem now and this is what i replaced:
Fuel pump
Fuel Filter
Crank position sensor
Air intake sensor
Throttle position sensor
Fuel injector
Pressure Regulator
-The ignition module is good (checked @ autozone)
-ALL fuses are good, checked and rechecked
-Enough fuel pressure at carb
Still not running.
Old 07-27-2008, 05:23 PM
RC1488 RC1488 is offline
As stated above, you need to do more diagnosis on your own.
First thing is to check for spark at the coil towers (where the spark plug wires connect to). Yes no?
Next is there a humm when the key is in the RUN position. This should last for 2-3 seconds.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
