Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 06-15-2007, 11:19 PM
mattyj8589 mattyj8589 is offline
Is This Right
so i got a 96 neon today if i pull a 2.0 dohc engine,harness,an ecm and 5 speed and the shifter and linkage and clutch pedal with the cable also a 2.4 from a strats from the junk yard i should just be able to bolt the tranny to the 2.4 and the 2.0 head on the engine plug it in the ecu and be all set .......are both the 2.0's axles the same or which ones would i need.....seeing how i'am using the 2.0 head i should'nt run into the cam timing problems???? what hp do the 2.4's have stock ?
Old 06-19-2007, 12:03 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Is This Right
2.0 DOHC and 2.4 DOHC heads are identical. The 2.4 DOHC is rated the same HP wise as the 2.0 DOHC neon engine...150HP. The difference is in the torque rating...160 ft/lbs for the 2.4 as opposed to the 2.0's 132 ft/lbs.
2003 Dodge SRT-4
