Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-15-2007, 11:18 PM
Bethbabie Bethbabie is offline
Talking 1993 jeep grand cherokee trouble with idle??
I love my Jeep I have had it now for about 3 years and for the most part it hasn't given me any trouble. About 3 months ago is when this whole thing started. When I start the engine the idle won't kick down, but it dosen't do it all the time and when it's not high it will go up and down.
Now for a list of things I have had done so for.
full tune up- new wires, new Distributor and cap
new fuel filter and air filter
new o2 sensor
have had all fuel injectors tested and seem to be fine
have had system checked for vacum leaks
Over the last 3 months I have put over $900.00 into solving this trouble.
This jeep dose have over 150 thousand on it, I'm just not sure it's worth putting more into. I would really like some feedback on this.
Thank you.
Old 06-16-2007, 12:34 AM
Ron68 Ron68 is offline
Re: 1993 jeep grand cherokee trouble with idle??
Check the IAC (idle air control) solenoid.
2004 Grand Cherokee Overland (DD)
2000 Ford Explorer (Daughter's ride)
1986 Ford F-150 ( Ridge Runner)
2002 Mercury Mountaineer (Mama's ride)
1968 Ford Mustang Coupe (modified a little)
"If it ain't broke, then don't fix it."
Old 06-17-2007, 08:51 PM
bringselpup's Avatar
bringselpup bringselpup is offline
Thank you.
Hush your mouth.
Mine has 213K and shows no signs of quitting. I put over 400 miles on it this weekend and averaged 19.5 mpg. There's a lot of info regarding cleaning the TPS and idle issues. I would do as Ron suggests and look there since you've done a lot of the other general maintenance items.
93 ZJ White 4.0L PowerTech I6 with +215K miles - Brembo up front Yakima on top Red Top under the hood
Old 06-18-2007, 07:22 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
If there is no vacuum leaks, then it is deffinately an IAC issue like RON mentioned.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
