Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 06-15-2007, 08:49 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
PCM Reprogramming
1998 Jeep Grand Cherokee 5.9Limited
On my PCM there is a sticker for PCM reprogramming.
P/N: 56041519AC
Dealer Code: 612274
Date: 10-29-98
4275086
Can anyone tell me what this was for or where I can find out what it was.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 06-15-2007, 09:13 PM
xj31 xj31 is offline
Re: PCM Reprogramming
Does it look like this ?your pcm was reprogrammed.there should be something where it says change authority.Whoever flashed it is supposed to put the tsb number there.Also that sticker is supposed to go by the emissions label,there is a small one for the pcm
Old 06-16-2007, 06:26 AM
Yes this sticker is on the HOOD and there is a smaller one on the PCM (that is where I got all the info from), the one on the hood is very hard to read. but is gives the same info as the little sticker on the PCM, and it says UPDATE JTEC. But doesn't say anything else.
Old 06-16-2007, 07:32 AM
Bob D. Bob D. is offline
It could have been re-flashed due to a recall - only way would be to ask the dealership or Chrysler. Chrysler should have a record if it was a recall flash.
Old 06-16-2007, 07:46 PM
I hope they didn't do this:NO: 18-28-97
SUBJECT: Premium Unleaded/Regular Unleaded Fuel Selection
DATE: Aug. 29, 1997
NOTE: THIS INFORMATION APPLIES TO 5.9L ENGINES.
DISCUSSION:
The 1998 5.9L Grand Cherokee was designed to use Premium Unleaded fuel. This selection was made to maximize the horsepower and torque from the engine. Some customers may prefer using Regular Unleaded fuel due to cost factors associated with using premium. If a customer prefers using regular fuel, the software of the powertrain control module will require flash programming to prevent driveability concerns. The regular fuel calibration will reduce engine horsepower and torque.
This flash program procedure will allow a technician to select either a premium fuel calibration or a regular fuel calibration. These calibrations can be re-flashed from one to the other at any time.
NOTE: THIS CALIBRATION SHOULD BE CHOSEN BY THE CUSTOMER.
EQUIPMENT/PARTS REQUIRED:
QuantityPart No.Description1CH6000Scan Tool (DRB III)1CH7035General Purpose Interface Bus Cable (GPIB)1CH7000/7001J1962 Cable104669020Label - Authorized Software Update104275086Label - Authorized Modification
NOTE: THE MDS AND DRB III ARE REQUIRED TO PERFORM THIS REPAIR AND THE SYSTEM MUST BE OPERATING WITH RELEASE 21 OR HIGHER AND TIL CD RELEASE 1140 OR HIGHER MUST BE INSTALLED.
PROCEDURE:
This procedure involves selectively erasing and reprogramming the Powertrain Control Module (PCM) with new software (calibration changes).
  1. Connect the MDS (Mopar Diagnostic System) and DRB III (Scan Tool) to the vehicle and power them up.
  2. Use the arrow keys and select #2 MDS DIAGNOSTICS on the DRB III MAIN MENU Screen.
  3. Use the arrow keys and select DIAGNOSTIC MENU on the MDS, then press NEXT MENU.
  4. Use the arrow keys and select VEHICLE CONTROLLER PROGRAMMING on the MDS, then press NEXT MENU.
  5. Use the arrow keys and select PROGRAMMING OF ALL OTHER CONTROLLERS USING MDS & DRB III on the MDS, then press NEXT MENU.
  6. Follow the steps presented on the MDS and DRB III which will allow the DRB III to obtain the current part number of the PCM.
  7. The MDS will display the part number of the PCM on the vehicle and the appropriate replacement part number(s). Select the appropriate calibration either for Regular fuel or Premium fuel, then press NEXT MENU to begin programming.
  8. The MDS and DRB III will prompt for any operator action needed during the remainder of the programming process. NOTE: THE FOLLOWING STEPS ARE REQUIRED BY LAW.
  9. Type the necessary information on the "Authorized Software Update Label" p/n 04669020. Attach the label to the PCM and cover the label with the clear plastic overlay.
  10. Type the necessary information on the "Authorized Modification Label" p/n 04275086. Attach the label near the VECI Label.
POLICY: Information Only
Old 06-16-2007, 08:12 PM
I don't know. I guess I will have to call the dealership on monday. I hope they didn't do that one, if so I will have them change it back. I always run PREMIUM fuel anyways.
