stereo
i bought the factory six disc changer off somebody on a forum. i need to know how to take apart the stereo dash to put it in. is this hard?? does any one know how this is done?? any help will be great. thanks
Friends Don't Let Friends Drive Stock-K&S Racing Development www.kandsracing.com AEM CAI Custom Apex-i N1 cat back |
1.) open top compartment.
2.) Grab the latch and pull the entire compartment out of the dash. 3.) Set on top of Dash 4.) Pull off the bottom trim piece (the piece that surrounds the little open compartment where your 6-disc will go) by grabbing the outside bottom corners and pulling forward. 5.) Unscrew the two silver screws above the head unit. 6.) Unscrew the two silver screws below the open compartment. 7.) Unscrew the two silver screws beside the climate controls 8.) Pull out entire center console assembly. 9.) Remove two little screws on each side of the open plastic compartment. 10.) Wire your 6-disc. 11.) Place 6-disc between the metal brackets where the plastic compartment was. 12.) Replace screws (6-disc will have compatable screw holes in sides) in 6-disc. 13.) Insert everything back into original position. 14.) Replace screws. 15.) Replace plastic dash components. The only thing I don't remember for sure about this is whether or not you will have to do #7. I can't remember if you have to remove those two screws or not? You will figure it out!!! If you need more detailed instructions, or you get stuck on something, or you run into an unexpected complication, let me know. I am you will have no trouble. Take Care! Good Luck! GB |
thanks gb
