Old 06-15-2007, 05:27 PM
burchboy19 burchboy19 is offline
95 keyless entry
i have a remote that i want to program to my 95 grand am, but i cannot find the program, does anyone have it? thanks
Old 06-19-2007, 11:31 PM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Re: 95 keyless entry
1-Open trunk
2-Remove right rear trim panel
3-Taped to a harness near the antenna mast is a single pin plug going no where. Wire color in that plug is probably black/white.
4-Ground that wire. The door locks will respond by locking, then unlocking
5-Press and hold Lock and Unlock buttons simultaneously for 10 seconds
6-The doors will lock then unlock indicating the system has learned that transmitter
7-Repeat step 5 for all remaining transmitters
8-Remove ground from the program jumper
9-Verify proper remote functions.
The keyless reciever appears to be mounted to the right side of the right rear speaker in the trunk seperation panel. If you must go there because you can't find the program jumper where previously described, the program wire is in pin L. It is a black/white wire at the keyless reciever.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
Old 06-20-2007, 12:52 PM
i couldnt find either of the wires in my trunk.
