Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-15-2007, 03:12 PM
ulremember ulremember is offline
Steady on ABS light and flashing Brake Light
Hello to all
I am experiencing a steady on ABS light and a flashing brake indicator. They go off when I start rolling. Whe I stop they relight.
Any ideas? Thank you in advance
Chuck aka ulremember
Thanks to all!
ulremember aka Chuck Jr.
Old 06-16-2007, 01:17 AM
acme1 acme1 is offline
Re: Steady on ABS light and flashing Brake Light
I had the same problem, check for brake line leaks and bleed the system. My driver side rear wheel cylinder needed to be replaced.
Old 06-16-2007, 08:21 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Originally Posted by ulremember
Hello to all
It needs to be put on a ABS brake capable scanner and get ABS codes.
Post back codes for more help.
MT
MT
Old 06-18-2007, 09:02 PM
Thank you for the replies! I do have a leaking master cylinder I believe. Looing for the source of fluid now. Also, I came to the shop today and used the new Snap On Modis unit. Says no codes. But when I look at the data display, it "says" that my back wheels are going 44 mph. So I am now suspecting some faulty speed sensors. This all started when I put some solid core wires on the spark plugs. I have since change them (right after I put them on-the next day). I will check the leaks out and if you have anymore ideas, please tell me of them.
Thanks to all!
Old 06-18-2007, 09:20 PM
MT-2500's Avatar
AF - Advisor
Abs codes clear ever engine restart.
Always check for codes when light is on.
MT
