Old 06-15-2007, 12:12 PM
mightymaxtj mightymaxtj is offline
starting problem
engine turns over and starts fine but only runs for a few seconds then dies. fuel pump or filter? it is a '90 mitsubishi mighty max
Old 06-16-2007, 08:27 PM
GreyGoose006 GreyGoose006 is offline
Re: starting problem
could it be an anti-theft device preventing the car from running without the magnetic or whatever keys?
what else is it doing?
Old 06-20-2007, 02:09 AM
fat-lad fat-lad is offline
sounds like a fuel pump to me, can you hear the fuel pump (arm) whine when you turn the key before it starts??
Old 06-21-2007, 07:01 PM
INF3RN0666 INF3RN0666 is offline
What you said doesn't explain anything. What about sounds? How does it run (rough or smooth like usual)? I doubt a 90's car has a decent anti-theft system that shuts off the car anyways. You might want to make sure that your vacuum hoses aren't off or aren't torn. If it keeps running and turning off, I would doubt it's a fuel problem. A weak pump would probably give you a hard time starting the second time around.
