Old 10-29-2002, 12:22 PM
CRX586's Avatar
CRX586 CRX586 is offline
12V or 14.4V?
I'm looking at this amp's specs:
40 x 4 + 150 x 1 @ 12V (4 OHMS)
60 x 4 + 200 x 1 @ 14.4V (4 OHMS)
So which one applies?
02 Lexus IS300
Old 10-29-2002, 12:34 PM
chucksnee chucksnee is offline
It depends on what your ALT. is putting out, if your ALT. is putting out 12.4 then the first set of figures applies if your ALT. is putting out 14.4 then the second set of figures applies.
Take a volt meter and start your car, there are 2 places to check your volt's coming off your ALT. 1 is the battery and the other place is the power wire for the AMP where it connects to the AMP. that will be your volt reading.
Hope this helps
:frog:
Old 10-29-2002, 06:29 PM
delsolsi delsolsi is offline
Your battery puts out 12 volts, your alternator puts out 14.4 volts. So when the engine is off your getting 12 volts, when your engine is running your getting 14.4 volts.
Old 10-29-2002, 08:22 PM
GSteg's Avatar
GSteg GSteg is offline
Send a message via AIM to GSteg
those 2 statements above would be true, if you're not getting any voltage drop through the power wire
I love them sub wufers
Old 10-29-2002, 10:04 PM
If you use the proper size power wire you should have a minimal, if any, voltage drop.
Old 10-29-2002, 10:05 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Power wire isnt the only factor determining voltage drop...
AF's Official Asshole
RIP AUNIE
Old 10-29-2002, 11:51 PM
GSteg's Avatar
ok..no corrision (spelling?) in the wire also
Old 10-30-2002, 01:07 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Also outside tempature can affect it. In the early morning, my car puts out about 14.6 volts, during the day on a mild say in the 60's day it puts out about 14.1 volts, and on a hot 90+ day it puts out about 13.5 volts unless I'm on the highway for a long period of time.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 10-30-2002, 08:25 AM
I agree with all your statments, just wanted to get the basics out to him becaquse like you said depending on the weather and so on it could change the out put of the ALT. some low some high.
I know in my truck that at the amp i was still getting 14.4v with kinda shitty wire while at the alt. it was still 14.4v.:smoker2:
Old 10-31-2002, 06:59 AM
turbcivic's Avatar
turbcivic turbcivic is offline
14.4 volts to the amp is kinda of hard to get. Your car will usally trun only 14.1 to 14.3 volts to the amp due to the fact that your car is running. Power is need to run the car so you will have a small voltage drop.
Old 10-31-2002, 12:33 PM
So are you saying that 14.4 is the most that an ALT put's out? i know that i was getting 14.4 at the AMP. some put out a little more and some a little less
Old 10-31-2002, 04:43 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
the biggest loser of voltage is the crimp connectors, and their connection to the battery, amp, fues holder, ect ... Remember too, that the fuse is essentially a very small wire inline with the power wire. As for Alts, it's a known fact that they put out less power when they get hot - just like all electronic items. It's normal for an alternator to have a dual rating that looks like 140/120 amps (cold/hot).
Old 11-02-2002, 06:15 AM
MyFirst4G's Avatar
MyFirst4G MyFirst4G is offline
Send a message via AIM to MyFirst4G
Yea, this guy is 100% correct, oh, and to measure this, what i did was Buy a Digital Farad Cap and put it in my car, this also helps not to drain your battery and it wont make your ALT whine, and it will stop your headlights from dimming...
88 DX Hatch SOLD!
90 Si Hatch Wreck'd :
Done parting out.. Shell is going to fire dept soon to get roof chopped off for some kind of drill.. wait for the movie!!
96 Saturn SL2:
Daily Driver untill 91DX is running!
91 DX Hatch:
Its gonna be Painted CL Type S Grey w/ WW RS kit from 90 Si and JDM CRX front end conversion... Powered by a Turbo'd GSR Motor..... Loot is on the way!!
Official 4th Gen OG
Hype Race Crew
Old 11-02-2002, 08:23 AM
Audio Guy
unfortunately, the digital stuff on the top of the cap raises it's ESR to the point where it is useless for the intended purpose, caps do not prevent alternator whine, and they only work on some cars for preventing the lights from dimming.
Old 11-15-2002, 03:26 PM
guysohigh guysohigh is offline
Send a message via AIM to guysohigh
Don't Get A Cap
I bought a Digital 1.5 Farad Cap to stop my lights from dimming, didn't work. Caps aren't guaranteed to do anything but look good beside your amp.
