Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-14-2007, 09:08 PM
danim3000 danim3000 is offline
Chevy Suburban 1990
Where is the location of the crankshaft sensor in the 1990 chevy suburban?
Old 06-14-2007, 09:23 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Chevy Suburban
Does the 1990 Suburban have a crankshaft position sensor? I don't think so. What engine is in it, 5.0 or 5.7 V8? 7.4 V8? 4.3 V6?
What is the issue you are having? These engines all had distributors at the time.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 06-15-2007, 09:46 AM
Blue Bowtie's Avatar
Registered Offender
Re: Chevy Suburban
The SandMan is right. A 1990 should have had a conventional HEI distributor, EST system, and triggering via the pickup coil in the distributor.
Are you reading some sort of error code indicating a CKP signal problem?
Old 07-07-2007, 06:54 PM
csamford csamford is offline
Re: Chevy Suburban 1990
It should not have a crank shaft position sensor but it will have a knock sensor, which it similar, whats the problem?
