Old 06-14-2007, 12:06 AM
paxfam1 paxfam1 is offline
Bad Gas Mileage!
Ok. 1991 Silverado 350TBI
I am gettin 9MPG I have done everything I can think of to improve mileage.
plugs
wires
cap
rotor
fuel filter
air filter
foamed throttle body
Motor is stong, burns under a quart of oil every change.
has 181,000 miles on it.
I cant figure it out. What would help???
Old 06-14-2007, 12:22 PM
BowtiePowerhouse BowtiePowerhouse is offline
Re: Bad Gas Mileage!
bad o2 sensor, plugged exhaust / cat, clogged or broke injector, just a few to add to your list
1994 C1500 5.7L
Work in progress...
Old 06-14-2007, 01:41 PM
bigcoconut bigcoconut is offline
What size truck and what size tires? Larger tires will sink your gas mileage because they effectively change your gear ratio.
I had a 91 extra cab, 1/2 ton, short bed, 350TBI, with a fiberglass shell on the bed and a Gibson 3" cat-back exhaust. I was getting around 13-15 (city-highway) but after I put 31 inch tires on it I was getting around 11-12 mpg. I now have a 92 regular cab, step side, 350TBI and I'm getting 13-18 (city-highway) on this one with stock tires.
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 06-14-2007, 03:49 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What is the foamed TBI?
Base timing ok?
Any codes?
Is the coolant and air tempt reading good to the PCM?
MT
Old 06-14-2007, 06:33 PM
jocat54 jocat54 is offline
I had a bad egr solenoid on my 93 350ci and no check engine light--mileage dropped from 17-18 hwy to 10-11
2006 VW Jetta TDI Diesel (Super fuel mileage)
2004 Chevy 2500 6.0 Crew Cab
1993 Chevy K1500 5.7 (love this truck)
Old 06-17-2007, 10:05 PM
sub006 sub006 is offline
Maybe a pinhole in a fuel line that only leaks under pressure (while running)?
Doesn't always happen where you can easily smell gas.
At hgher mileages (my '90 Suburban is at 419,000) simple yet hard-to-find little things start to happen.
Old 06-27-2007, 11:54 PM
Okay sorry for the delay in my post,
I have dual exhaust w/ no cat.
265/75/16 tires.
I guess I am unsure how to check the base timing. Seems powerful, doesnt miss or anything.
The only things I notice out of the ordinary are, A)The tach bounces around alot like within a few hundred rpms. B) once in awhile when I put it to the floor the oil pressure guage will peg.C)I can smell raw fuel when the truck is parked but it doesnt drip or anything.
I dont no about bad egr or o2 sensors, the o2 sensor is right in the manifold so pulling the cat shouldnt affect it much.
BTW bad gad milage before cat was removed, so thats not the problem.
The foamed intake was this can of intake cleaner I got and while the engine was running you spray it in the intake and then I shut the truck off and let it sit over night, then in the morning I ran it, but it didnt seems to do much as far as I could tell.
Old 06-28-2007, 08:57 AM
MT-2500's Avatar
AF - Advisor
Good old basic tune up and a scanner check would be first on my list.
Tach bouncing and gas smell spells problems.
And no cat can sometimes make things worse.
MT
Old 06-28-2007, 09:44 AM
I did a full tune up before I posted, as I mentioned in the first post. My neighbor has a handheld scanner, should I hook it up to that?
Old 06-28-2007, 10:06 AM
MT-2500's Avatar
AF - Advisor
Reread post 4.
A good full tune up includes good ac delco plugs code check and base timing and all scanner readings compression check and fuel pressure check and many other things.
Watch your tempt sensor readings on scanner.
Is the engine running up to proper tempture?
And you should get a cat back on it.
Has it ever got any better gas mileage?
What is the gear ratio?
4 W drive?
What sise tires?
What are your driving habits?
MT
