Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-13-2007, 10:18 PM
gunky gunky is offline
1995 bonneville oil pressure problems
in despret need of help 1995 pontiac bonneville 160k
replaced upper and lower intake gaskets after i put toghter found was leaking from timeingchain cover replaced gasket
which was leaking coolant upon reasambleing no oil pressure at all...... car had 40 at
idle until this project took place ......took apart many times packing oil pump with vaseoline
with no sucess what am i doing wrong please help
by the way this is a SE model checked all ports i dont see oil pump craping out from changeing gasket
BTW if i have high idle will pressure up until i let idle again confused
tx there is not any pressure iam gonna replace oil pump amd pressure reg keep ya informed
ok new pump had great pressure till enginge warmed up then gone WTF!!!!! please help junk yard is near
Old 06-14-2007, 05:21 PM
ru1313 ru1313 is offline
Re: 1995 bonneville oil pressure problems
you need to check it with a gauge from an oil port, not your instrument panel, and make sure you have pressure before you lose your engine.
Old 06-18-2007, 05:57 PM
whitecrystal1's Avatar
whitecrystal1 whitecrystal1 is offline
I take from reading this your uim/lim failed? How long did the antifreeze sit in the oil pan? Sounds like the main bearings are going bad. Most likely do the the intake failure.
Do like ru1313 said and check the pressure with a mechanical gauge and verify the pressure when hot. How low does the gauge read when hot? Replacing your t-stat to a 160deg and changing to a heaver weight oil may help keep your oil pressure up a little higher. It's not a fix but it may buy you some more time out of it.
1999 Bonneville SSEI L67 Dark Caribe Green Metallic 81K
2002 Buick Lesabre Custom L36 Ming Blue Metallic 45K
2010 Silverado Crew Cab LTZ 6.2L Max Black Granite 3K
2001 Wellcraft Martinique 2400 Merc 5.7L BIII 263hrs
1995 SSE L36 Dark Polo Green Metallic **R.I.P. 4/28/10 236,400 miles**
Old 07-19-2007, 07:42 PM
ok great i been foolin around with it now gave up must be main bearing is it worth rebuilding or do i look for a used engine
looking possibly for a engine in northern michigan at right price tx for all ur help
