Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-28-2002, 11:56 PM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
is it possible?
is it possible to have a digital boost controller, where you can having it running no boost?
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Old 10-29-2002, 04:37 AM
chad174 chad174 is offline
well you could try to make your wastegate stay open, but then your turbo wouldn't be experiencing any resistance forcing air into the motor, so the blades in it will spin too fast, possibly blowing a seal or overheating/seizing of the turbo. i may be wrong though, there may be a way to do it. if anyone knows, let it rip, i'd also be interested in that.
Old 10-29-2002, 08:29 AM
higgimonster's Avatar
higgimonster higgimonster is offline
I am sure there would be a way.
You could use some sensors to measure the pressure in the manifold and some solenoids to activate a wastegate to keep pressure at an optimal point.
Actually, now that I think about it Saab did that in there older cars (and probably the newer ones too). The unit was called the APC and it used a series of sensors (the primary of which is the knock sensor) to maximize boost depending on the octane of your fuel and other variables. It always put the maximum safe boost levels into the engine.
Promoter of the one line signature.
Old 10-29-2002, 08:49 AM
TheBum TheBum is offline
Send a message via AIM to TheBum
Small correction to what was said earlier. If you let your wastegate stay open continuously, your turbo would not spool up at all, instead of too much. The wastegate lies in the exhaust manifold, before where the exhaust gasses reach the turbo. It is there to let exhaust gas bypass the turbo, causing it to spool up less and create less boost.
I think you meant to say leave the blow off valve open continuously, which would yield something along the results that you said.
Old 10-29-2002, 08:57 AM
Just curious, were you correcting me or chad?
