Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 06-13-2007, 06:46 PM
Woody86 Woody86 is offline
Tranny on '99 Ram 1500
I've been having problems with my truck bouncing between gears or not shifting at all. I had it scanned and was told that it was the master governor solenoid. I already called and got the price on the part, how difficult will it be for me to change that out myself?
Old 06-14-2007, 06:39 PM
miner327 miner327 is offline
Re: Tranny on '99 Ram 1500
i think i have the same problem as you the obd code was p1757 on mine and it saidgov press above 3 psi in gear with 0 mph. the dealer just told me it was the governor pressure sensor. He said it it right inside the pan and i remember seeing the wiring the last time i changed the fluid so I dont think it will be too hard to change.
Old 06-15-2007, 06:43 PM
Thanks for the info. I'll take a look at it and see if i can do it myself.
Old 06-17-2007, 05:50 PM
troy1 troy1 is offline
AF -Advisor
Do the gov sol and transducer. Its a DYI job for sure 2 -25torx and 4 7/16 bolts torque the 25torx to 60 inch lbs and the 7/16 to 110 inch lbs.
