Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 06-13-2007, 12:58 PM
bighank bighank is offline
Montana with bad right wheel bearing should I change BOTH NOW
My 1999 Montana has a noisy right wheel bearing. Now getting ABS and TCS lights along with BRAKE lights on instrument panel. On a Corvette forum it was recommended to change BOTH wheel hubs and bearings if you changed one of them. One vendor (AAuto) wants $89 plus shipping for ONE and $149 for TWO bearings. Should I buy two of them and change them both. Montana has only about 65k miles on it. Thanks BIGHANK
Old 06-13-2007, 07:16 PM
1Bradymichael 1Bradymichael is offline
Re: Montana with bad right wheel bearing should I change BOTH NOW
Really no reason to change them both, you might get another 100k out of the other side. Not like a set of brakes, where the rule of thumb is "do unto one side as you would do the other"
Not sure what the TCS light is about though
Old 06-14-2007, 06:39 AM
Glen_T Glen_T is offline
My 2003 had the right side bearing replaced under warranty, and I got the traction control/ABS lights at the time of failure.
I'd only replace one side....Glen
Old 06-14-2007, 07:49 AM
mhall02 mhall02 is offline
So far I have just done the passenger side, the van ('99) has around 160,000 miles on it now and the driver's side is original. Who knows how long these last, I've heard like you, them going out at 65,000 and lucky ones like me with over 150,000 miles on it.
Old 06-14-2007, 01:18 PM
newfiejeff newfiejeff is offline
If you are in the mood and the bearing is not to costly, I would change it. I done one bearing on the front and 4 months later I had to do it for the other side, not to mention that I to get a loan of the tools twice.
Good Luck
Jeff
Old 06-14-2007, 02:26 PM
Wink Re: Montana with bad right wheel bearing should I change BOTH NOW
Thanks for the responses. Will check things out this weekend. Have since found a bearing for about $100 with Timkin bearings and lifetime guarantee not 90 days or 1 year, and not some no name bearings. If the right one is bad will start out replacing that one and see what happens. Can "borrow" the tools at autozone.
Old 08-15-2007, 01:05 PM
sdopson sdopson is offline
i have a 2003 montana that is making a humming noise as the speed increases, just wondering if you had a noise like this. i have no sensore lights on.
Old 08-17-2007, 07:13 AM
The sensor light didn't come on. Check your tires, I found that when the wheel bearing gave out it would be fine moving straight but made the humming noise when turning left or right depending on which one was gone.
Hope this helps
Jeff
opcorn:
Old 11-02-2007, 02:31 PM
remigh remigh is offline
Question for the wheel bearing experts: what are the symptoms in the Montana when one starts to go... thanks..roger
