Old 06-13-2007, 01:04 AM
redbaron1 redbaron1 is offline
Question blower motor relay
does the blower motor have a high speed relay ifso where is it located.
thank you
Old 06-13-2007, 11:05 AM
drew300 drew300 is offline
Re: blower motor relay
Mine quit too.
It's on a circuit board that's installed in the blower box.
You'll find by removing the rad overflow and windshield washer bottles.
I fixed mine. I found that the sealant had eaten a printed wire on the board, so I replaced it with a wire, and soldered it on. I was able to follow where the old foil was.
Old 06-13-2007, 01:55 PM
thanks for the info I'll check it out.
Old 06-15-2007, 06:46 AM
brcidd's Avatar
brcidd brcidd is offline
1996 and above is as described above---1995 and prior are mounted above HVAC module and not a part of the resistor board...........
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 06-21-2007, 09:33 PM
trip-l-jax's Avatar
trip-l-jax trip-l-jax is offline
My stepson has a 1994 Astro CS, the relay controls the high on the blower motor, and it is the rectangular relay above the HVAC unit near the heater water valve. My experience was the truck only had medium-high where the low and medium not working was the blower motor resistors. On the issue with the high speed not working, check for continuous power at the red wire of the blower high speed relay, if power is not there go to the far right (standing in front of the truck) fusible link in a weather pack connection that is behind the battery and is just below the fuse box wiring harness and check for power on both sides of link. FYI, these fusible links are fed from the pigtail off of the positive battery cable.
My experience was the metal female part of the spade connector had plastic from the connector getting hot and insulated both metal connectors without burning the link, scraped the plastic out and power was restored to the relay, with the high speed now operational.
ASE Certified Automoive Technician
Surface Maintenance Mechanic- INARNG
